WIP (leaking light)
  • WIP (leaking light)
    i tried to eliminate that light leak under my bonsai,
    move it up, move it left, right, the weird thing is if i render region that particular part, that light leak goes away. anybody care to enlighten me in this matter? thanks
    [img][/img]
    Dominique Laksmana
    i think its in the ray bias.
    if you find a bug...kill it.
      What is the material for the table?
        thanks for responding vlado, here it is
        [img][/img]
        [img][/img]
        Dominique Laksmana
          Ok then, and what is producing the light from underneath the table? A light or a self-illuminated objects?
            a sphere vray light, small one, 2cm in radius. unticked affect specular. very dark brown, intensity 1000
            Dominique Laksmana
              It would be best if you can get me that part of the scene to vlado@chaosgroup.com (just the table, the light, and the tree) so that I can investigate better.
                ok will do it in about few hours... client rushed me to render the thing, after rendering, i will hand it to you
                thanks vlado
                Dominique Laksmana
                  On another note... sweet render dude
                  Really starting to like your style. Very solid!!
                    thanks man, i really need that... tired... very tired.....
                    Dominique Laksmana
                      i have sent the file to you vlado, thanks a lot!!
                      Dominique Laksmana
                        Yes, thanks, I got the file; the problem was that the light cache samples from the bottom of the table leak onto the bottom of the plant. The way I solved it was to assign a different GI surface ID to the plant from the V-Ray Object settings dialog, and to turn off the prefiltering for the light cache (there was a small bug where prefiltering did not respect the GI surface ID, but this is fixed now).
                          cant seem to find object ID in the object setting dialog.
                            It is here:
                            • #15
                              thanks vlado! really appreciate that.
                              so vlado, what's the cause for this? is it the light intensity is too strong? or the material itself? thanks again
                              best regards,
                              Dominique Laksmana
