Fun with Reactor
  • #16
    That would be interersting (dof pro ae), but can it be a realtime effect ? As in PS it works not in realtime. Even not near to realtime.
    I just can't seem to trust myself
    So what chance does that leave, for anyone else?
    CG Artist
    • #17
      Ok heres a stupid question, Ive done stuff with blocks like that before with reactor but how do you position the objects when you are stacking them? I could never get the spacing right between the blocks and if I used snap to put them together it would bitch that they were intersecting so I had to leave a small gap which would cause the wall to collapse or settle slightly when running the simulation... Then again this was with I think max 6 or 7 :P
      -dave
      Cheers,
      -dave
      ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
      • #18
        the easiest way is to let the sim settle, say before frame 0, and run the proper one afterwards.
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
        • #19
          Richard,
          Now all you have to do is put everything together and make yourself a Rube Goldberg machine...
          Needs more cowbell
          • #20
            I actually found one that I did a couple years ago... http://www.syclone3d.com/vray/explode_brick_sm.mov
            Cheers,
            -dave
            • #21
              Whoa - didn't realize there were so many posts to this!
              Blitterswitch - GI is simply single frame irradiance map with a sampling of -1, -1.
              Syclone1 - Good question. I create a long cylinder, then use the scatter tool to scatter the cubes around the cylinder and not have them intersect one another . Then remove the cylinder and they are ready to be dropped.
              Da_elf - DOF PRO is being worked on and there are some SWEEEEEEET additions that are pretty impressive. Should be out in a few months I think. However, no AE version as it requires a complete re-write using a totally different SDK.
              -Richard
              Richard Rosenman
              Creative Director
              http://www.hatchstudios.com
              http://www.richardrosenman.com
              • #22
                ive always wondered how you would get BG0012.tga from folder "background" to use Z0012.tga from folder "Z_buffer" and then apply all of this on matching sequencial images
                • #23
                  Hey Da_elf;
                  That should work fine - it would help DOF PRO if you properly pad the filenames ie. BG_0012.tga and XX_0012.tga.
                  -Richard
                  Richard Rosenman
                  Creative Director
                  • #24
                    DOF Pro in photoshop can do sequences? wow cool. i never did get to buy it so ive no idea how it worked. you did have a demo or something a whiiiiile back that i tried but not seriously. if you went AE that would be cool since you could change the field of view. maybe if you can get some sort of script that the plugin can access like a text file with the settings to use per frame. terragen used to have scripts like that
                    • #25
                      Hey Da_Elf;
                      You should check it out - it's been quite developed since you last saw it. It can do full sequences within the filter AND full keyframing within the filter as well so yes, you can animate the focal depth, and any other feature (ie. bokeh curvature, intensity, rotation, etc, etc).
                      It have virtually every feature it would have in AE, but in PS.
                      Check it out: http://www.dofpro.com
                      -Richard
                      Richard Rosenman
                      Creative Director
                      • #26
                        hi richard,
                        after using the scatter tool, the blocks are one object. how did
                        you get every single block into the rigid body selection?
                        detaching one for one?
                        max 9 + vray
                        • #27
                          Originally posted by bluescreen2
                          hi richard,
                          Same question here, please. I did scatter for a forest once, but after, all the trees were one object...
                          Very cool animation Richard!
                          Thanks
                          • #28
                            I just ran a simple test right now guys and the boxes remain seperate objects...
                            I'm using Max 8 and the Scatter tool found in the tools menu...
                            -Richard
                            Richard Rosenman
                            Creative Director
                            • #29
                              strange. in max9 its one object.
                              max 9 + vray
                              • #30
                                I don't see a "Scatter" tool in the Tools Menu under Max 9. Are you refering to "clone and align" or prehaps the "spacing tool"?
