5 000 000 000 000 polygons
  • I've tried running the demo installation of one of our rendernodes but no joy. How do I get the demo to work using DR?
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    • sorry i don't understand that you try the DR with te DEMO ... so i haven't try it with DR, but i know that the R&D team answer my questions quickly when i have...
      Maybe they could send to you a node render without limitation...
      i ll be back
      http://www.vincent-grieu.com
      • Thanks Duke - I think it's the file with an "r" in it though, I will give it a try.
        Tricky: DR does not work with the demo AFAIK. I had to run my tests without it unfortunately.
        b
        Brett Simms
        www.heavyartillery.com
        e: brett@heavyartillery.com
        • Originally posted by simmsimaging View Post
          b
          Yes - just had that confirmed. Its a pain to test as we do all our rendering with DR. With the one test machine, we are finding it pretty slow going!
          Kind Regards,
          Richard Birket
          • I hear you on that - but I was totally blown away at the speed of the rendering setup with VrayScatter. It works as advertised - no question about it.
            Brett Simms
            • I have 10 DR nodes, it works pretty well except sometimes if you cancel the render before it finishes you get an error message and basically have to restart Max.
              • VrayScatter trial uniforms color?
                Hi there, now I'm trying to use Vray Scatter in the trial. It seems to me that the loaded Vray Proxys, are all incoming in one color........ what is happening here? Is this just the plugin is only trial?
                When I prepare the models, and proxy them, in the old way of working there is nothing wrong. Loading and rendering nice, but slow......
                Thanks, Remco
                • VrayScatter forum
                  VrayScatter forum here, might help posting there.
                  http://rendering.ru/phpBB3/
                  • Yes the proxies will be given a default color once they are scattered, you need to do the following to preserve their textures.
                    -select proxy and load material into the material editor
                    -scatter proxy
                    -select scattered group
                    -apply material back onto proxy
                    I've brought this up as a bug that needs to be fixed, I don't know if the language barrier is keeping them from understanding me but they tell me it's not a bug and that proxy materials can't be preserved once scattered or something close to that. I hope they fix it because it's a real nuisance that shouldn’t be there.
                    • dont know if this was asked before but is there is demo for the 64bit version?........... never mind
                      • I think yes, cause I'm now running the demo on 64bit
                        • Some more messing about with VRayScatter
                          Best thing since sliced bread................
                          Laters
                          • i tried the demo on max2009 64bit and the settings were all screwed up. dont know what happened. if i move the spinner on one setting, another one changes. some are left blank
                            • hey, AlexDuche, did you get my messages?
                              • Originally posted by Da_elf View Post
                                It is seems, that you use WorkStation version without licence, not demo.
                                sorry for my English
