First almost clean VolumeCaustics
  • First almost clean VolumeCaustics
    Hi
    Now when I'm not so busy, I continued to test new Vray features.
    This took 4.2 hours to render.
    (render settings could be too high, but I wanted to get clean results)
    I had to boost caustic subdivisions for spotlight to 14000 and it's not enough.
    There is till some soft large noise.
    Anyone else had luck with Volume caustics?
    Any tips to make it faster, more detailed?
    -LarsSon
    Lasse Kilpia
    VFX Artist
    Post Control Helsinki
    Rendertime 4,2 hours on what kind of system? With DR?
    Cheers, Dirk
      HP 8400 dual quadcore with 8GB memory.
      No DR.
      Lasse Kilpia
      VFX Artist
        What were your caustic settings?
          Caustic settings:
          Multiplier: 1
          Search dist: 0.7 cm
          Max photons: 0 - so it uses all available photons
          Max density: 0.3 cm
          Spotlight: caustic subdivisions: 14000
          Env fog subdivision: 256 - might be way too much, but normally that isn't
          slowing rendering so much.
          Lasse Kilpia
          VFX Artist
            You can try to use non-zero "Max. photons", and somewhat larger search radius, it may help to clean the low-frequency noise.
              Looks great...what are your fog settins out of curiosity ?
              Regards
              Steve
              My Portfolio
