Another project using Peter's HDR's. There are 28 images for this project showing different times of the day. The scene is created using 3d meshes for Gravel, Grass and Bushes using Vray Mesh Export. Grass and Gravel were distributed using Advanced Painter. Roof tiles is a displacement map. Everything apart from the Landscaping was modelled in Sketch up. This was my first Sketch up model and I can say I will never model architecture in Studio Max again.
House is a refurbishment, in open ground in Naas, Ireland. The existing part of the house is basically where you see the traditional Pitched roof, everything else is new.
I used 1725 Sun, 0743 Cloudy, 2003 Dusk and 2009 Pink available here at Peter's 3DOcean Store
You can see larger versions at the Flickr pages linked below.
Flickr Set Sunny
Flickr Set Mix
Overall I am very happy with the way these turned out, especially has this is basically my 'Rig' now. Work took approx 3 weeks from start to finish. What I love about the workflow I have at the moment is the ability to change the time of day in a matter of minuets using HDR's. The Sun and Vray Dome are linked to the Material editor so all I have to do is switch sets on and off and rotate them to wherever I want them. I remember the days of spending days and weeks on daytime shots and then dreading starting the night time shots. Living in Rural Ireland we get some amazing weather so I hope to start making some HDR's here!
Thanks for listening!
Flickr Set Sunny
Flickr Set Mix
