Vray render problem.
  • Vray render problem.
    Hii to all.
    I'm making an scene with Vray. Just I finished the modeling, and start to put materials to the mesh. I have a problem. When I render with scanline, the image it see good, but when I render with Vray it looks very different. What happens? help!!
    Scanline Render:
    Vray Render(GI):
    I would say that the little teeth are probably produced by a multi-sub object mat you're not aware of. Try applying a material modifier to it or sampling the material to inspect it. It's almost hard to say without more information though. Can you tell us exactly which difference you'tre talking about? I see a few, are you talking about the noise in the material.
    I don't know if this is how close you'll get in the end but take a look at your shadow settings also. Looks like you have a shadow map with too low resolution, it's visible below the object and in a few other places.
    --Jon
      id definately recomend using vray shadows
        Yes I'm talking about the teeth shadow. I just aply a material and it appears that teeth. I change the material, aply other and continue appearing the teeth
          If by teeth you mean the jagged dark edges at the bottom of the image, thats an artifact of using a Shadow Map with too low resolution to show the detail of the image..
          Suggest either using a Vrayshadow for raytraced type shadows (Or blurry).. Or upping the Shadow Map Size for your back light by at least double what it is now (Defaults to 512pixels)
          Dave Buchhofer. // Vsaiwrk
            Nevermind! i see what you mean now.. I'd say to check 1: your materials for the object, and 2: that there isn't really 2 objects there that are on top of each other..
              notoiara:
              If you can, upload a small section of the model that has the problem someone will figure it out.
              --Jon
                Here there is the model that cause problems. This is the link.
                http://www.terra.es/personal7/garbag...reimg/test.zip
                  Hi!
                  Your mesh had some faults... Backfacing polys coming through - if you want a fixed version, drop me a message with your eMail (max5 or 3ds possible)
                  Greetings,
                  Michael
                  This signature is only a temporary solution
                    Forgot to mention: Just make your material twosided and you'll see the mistake yourself
                    greets again
                      Oh yes! it was the mesh. I will try to fix that. Thanks to all.
                        Well, here I post an update of the WIP radio. Dont look at the floor texture, I will changed, and its not scaled yet. C&C thanks.
                          Hii to all.
                          I post an update. It's near to be finished. I want to model a car key, and somethings more, and the scene will be ended. I would like any comment at this point of the scene'¡s stage. Thanks
                            I realy like the last one.
                              The radio looks good, but it's in a wrong environment imo. Take a look at some advertising pics for such things and see hwo they present it. Personally, I wouldn't drop my radio on the floor
