so disapointed compare with Octane
  • so disapointed compare with Octane
    Dear Vray user,
    We just purchase Vray GPU pre order, and test it today.
    First of all, our choice to buy vray have been taken after testing Octane render. We test it on a 3 years old laptop with a quadro FX 1800 and the result was so fast that we have been looking around for other competitors.
    After looking around for several week,on CG forum, vray video demo of GPU... We finally decided to go for Vray as it seems to be the standard for Interior architecture due to its fast rendering biais engine.
    So we though, Whao!!, if a brand new beta engine like octane can make it so fast on a old laptop with a entry range video card, Vray , as a major player in the rendering engine with it's new GPU engine will rock.
    So we bought a FX5800, installed it in a brand new Dual X5650 computer, with Win7 64bit... everything to be as much as possible on the top line within , of course, a budget in mind.
    Now let's go back to reality : we just setup a basic scene, just one skylight, overide material everywhere with exclusion of the windows and door to let the light from outside to step in and the result is: incredibly slow.
    At least a lot slower than a render with the RT cpu and I guess, from the little time we spend on octane, 10 time slower than Octane in beta stage.
    So I really wonder, how other Vray user on this forum, enjoy so much this Beta!
    We joined the scene, in case somebody got the time to test it on a similar graphic card, just to sort out what's the problem, if there is one of course.
    Well. Show plz your results with octane. Also what algorithm you've used ?
    RT GPU
    Mine:
    3s25 = 400paths
    Lower the GI bounces to 1:
    0m25s = 400paths
    GTX280
    CG Artist
      Iam really disapointed too about RT GPU. I have GTX 295, two cores and it slow. Its sometimes maybe 3x faster then CPU, but I have Core2Quad at 3GHz, Core i7 what I have at work is 2x faster then my CPU at home, so It will be almost no difference at work.
      When I have time, I will try Your scene.
      AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
      2D | 3D | web | video
      jiri.matys@gmail.com
      https://gumroad.com/jirimatys
      https://www.artstation.com/jiri_matys
      https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
      https://www.instagram.com/jiri.matys_cgi/
      https://www.behance.net/Jiri_Matys
      https://cz.linkedin.com/in/jiří-matys-195a41a0
        Here are the screen shoot of the Vray RT setup.
        Unfortunatly, GPU is not faster than CPU as seen on here, at least not on this basic scene and not with this version of Vray GPU.
        It will be a good idea to put the true benchmark on line instead of marketing video spread around the web.
          In that scene my CPU is ~520KPaths/sec and GPU is ~700KPaths/sec.
          CPU: i7-860 @ 3.8GHz (8GB RAM)
          GPU: GTX 260 (896 MB Vid RAM) OC @696MHz
          What I don't like about GPU is the lag I get. But, wireframe views in 3dsmax is incredibly slow compared to XSI or Maya (or anything else), which bothers me a lot more than the lag in vray-rt-gpu. I can't figure out why 3dsmax wireframe views are so slow. VRay is the best part of 3dsmax, imo.
          The beta seems fine. I was expecting something faster. Octane has it's own problems. Shader creation is really slow and unstable, last beta I tried. They probably are wise to use only NVidia CUDA, though. Only one GPU to worry about, which is probably why it's so fast. It would be nice if Chaos Group at least tried CUDA-only option. But they are smarter than me so maybe when ATI gets it together with OpenCL support, they will have a great GPU solution, too.
          Also, let's not forget what RT is for. Previewing lighting and shaders w/ G.I. in near RT is extremely helpful. Try going back to mental ray final gather/GI calculation tweaking after using RT for a while and you'll see what I mean.
            Also good to keep in mind that Octane, while capable of doing a few things pretty well, does not have nearly the range that RT does. How much faster is Octane if you want to move two objects relative to each other? Or maybe add a spotlight or three?
            Octane is interesting and has some potential, but if it was covering the same ground that RT was it might not be or seem so quick. Just my POV.
            b
            Brett Simms
            www.heavyartillery.com
            e: brett@heavyartillery.com
              Guys, we need octane speed and settings used to achieve it. Where's it ?
              CG Artist
                Here is a small test of RT. The final sample # is dramatically higher on GPU. Shader support is lacking somewhat, but that's not a big deal to me.
                Also this is a very fast CPU and a not so fast GPU. It would be 2-3 times the total # of samples on a GTX 480.
                  I prefer the CPU version, the little things add realism, especially the penumbra of the sun shadow on the back wall.
                    For RT/GPU, an FX5800 (290 cores) couldn't be considered even remotely top-of-the-line for GPU rendering. Remember that the Chaos Group's tests were based on a machine with 4 GTX480s (1920 cores) on a single frame.
                    I just rendered your test file and it did what I would expect. RT/CPU (i7 3.2GHZ) rendered 726 samples in a little over 2 minutes, with RT/GPU (GTX 480, 336 cores) rendering the same 726 samples in under 40 seconds.
                    In the world of RT/GPU, cores are the ticket!
                    -Alan
                      Here's my cornell box V2 test. Just if anybody can convert it to octane - would be nice speed competition...
                      http://rghost.net/3293663
                      Max 2011
                      CG Artist
                        This is not rendered with RT, right??
                        Vray 2.0 looking really really good.
                        Andrian
                        _____________________________________
                        www.fekta.eu
                        Portfolio
                        CG Talk
                          Well, it was rendered with production vray. But, if you wish you'll get the same results with RT. Just slower.
                          CG Artist
                            I see, but the point was GPU renderer vs GPU renderer right? Production ready, biased renderer vs beta stage GPU unbiased renderer can't compete much, it will be unfair to battle them..
                            Andrian
                            www.fekta.eu
                            Portfolio
                            CG Talk
                              I even color corrected and distorted the result + glow to match the photo.
                              Open my scene and press activeshade (I set timelimit to 10minutes). Then, the guys, who're willing to compete - just convert scene to octane.
                              edit
                              Seems I included old version of my scene Will up later new one.
                              CG Artist
