Hdri test
  • Hdri test
    here I've tested to put an Hdri MAP.
    I put it in the background GI.
    Does the result is correct or my settings are bad?
    What kind of parameter I must change to erase this bad hexagonal effect under the teapot?
    [img]test hdri.jpg[/img]
    Cheers.
    Hdri test
    Sorry for the image, I've contacted joeb and i'm waiting for the link
      Hdri test
      When you want to post an image most people use http://www.imageshack.us - then post that link
      Also jpgs probably aren't the best bet for an hdr image - the jpg format is ldr.
      Joe Bacigalupa
      Developer
      Chaos Group
        Hdri test
        Ok, here is my image.
        I used an HDR image here.
          Hdri test
          Try flipping the plane over and see if it helps.
            Hdri test
            I confirm, this is a pb of reversing side.
            Thx.
              Hdri test
              Inverted normals are a bit of a problem in rendering in general, but more so in VRay. The other issue is that SketchUp isn't neccessarily very attentive to which direction normals are facing. If there is geometry that is causing issues 3 out of 4 times it has to do with either inverted normals or overlapping faces.
                Hdri test
                Thx for your instructiv post.
