I have had pretty good luck using the settings for basic architectural glass on the tutorials page. But with regard to the screenshot below I have two questions:
1. Why is the shadow from the sun in sketchup (left) different from the semi-rendered image (middle)? Notice the shadows at the base are not the same at all. I have unchecked the override options under both the GI and Background maps in the Environment tab and both are set to "default".
2. What settings do I need to change to the basic architectural glass to allow shadows to be cast inside the building (as it is on the sketchup model)?\
Thanks for any advice...
