My first renderings using Vray
  • My first renderings using Vray
    Let me know what you think.
    Re: My first renderings using Vray
    I think these look very nice, could you tell more about your scene setup, what lights did you use..
      thanks. ill try and explain how i set up the scene.
      For the Rims i put caustics on, Then I put the GI on under indirect illumination, and under environment I put GI on. Then I put a HDR bitmap using the spherical option. but the metal looked dirty because it was reflecting much so I put a white plane in front of the model so that it would reflect the white.
      For the Watch I did the same settings minus the white plane. Then in photoshop I rendered a lighting effect to give it that spot like look.
      I hope that makes sense.
        It`s very good for the first time.
