some mtl. test
  • some mtl. test
    vray linked mtl.test.
    Re: some mtl. test
    application.
      Re: some mtl. test
      im sold out, i love the spread of light from those transparent areas. any chance in writing a tutorial.
      http://www.nomeradona.blogspot.com/
      http://www.sketchupvrayresources.blogspot.com/
      http://www.nomeradonaart.blogspot.com/
        Re: some mtl. test
        I agree, this is a brilliant effect and would make a superb tutorial. Hint hint
          Re: some mtl. test
          Very nice work man ;D ;D ;D!!!
          I'm trying to get clip maps work either, but i can't :-\
          I do as you've done: i apply directly the clip map as a diffuse map to the object in SU, so i can take the holes down to the right size. Then i make a linked mat, and i set the clip map right where it should be. But just when i try to make a reflection layer (to make some sort of perforated metal) the reflection happens in the clipped parts too, even if i put the same clip map in the transmittance slot..
          So i'd very very like to see a great tutorial, like the one i'm sure you'll be able to do! ;D
            Re: some mtl. test
            Their is the Vray manual (PDF) to see this tutorial about clipping mask. on page 50, you will see a topic that will show about TRANSPARENTING MAPPING. for example, in the material editor, you want to change from color to image in the diffuse section (M button). and on the right is the transparency which you will have to change the color to image (M button). now for transparency the images has to in greyscale. black refers to mask and white refers to opaque.
              Re: some mtl. test
              Well i decided to show you the clipping mask tutorial instead. sometimes a pictures tells a thousands words rather then gibber jabber of explainations.
                Re: some mtl. test
                this is page 51
                  Re: some mtl. test
                  Hi
                  I've tried this transparency mapping from the manual and for some reason can't seem to get it to work. As anyone had any sucess with it. I'm sure there must be some setting that I need to change but haven't managed to figure it out.
                    Re: some mtl. test
                    Thanks for sharing this Howard & Graditec! Much appreciated.
                    Mike
                      Re: some mtl. test
                      I have to agree of what you guys mention about the manual of clipping mask. i did not work for me either. i messed around over a hour trying to figure it out and still i dont see any masking. I close the file and reopen it, also tried it in component groups buti dont get any results. hopefully dolomar might solve the problem.
                        Re: some mtl. test
                        i wanna make reply all of your questions, but i could not post my tut.
                        because this site prevent me post any reply.
                        so, i made tut about cylinder light, but i couldnt post it.
                        error has been occured couple of times!
                        sorry.
                          Re: some mtl. test
                          howardhong,
                          is it possible to upload it using file sharing free sites and paste the link.
                            Re: some mtl. test
                            Howard, why don't you just post(copy/paste)it in here in this thread.
                            Mike
                            • #15
                              Re: some mtl. test
                              Well everybody, i hate to mention this but i believe that we can no longer add attachment to the forum anymore. Mainly because it is full. I hope Dolomar and Joe might add more space to the forum. The only solution for now is to open an account from other servers for storage and just add links to the forum.
