yacht room
  • yacht room
    here is my first try of interior rendering, a room of a yacht. i am sure it can be improved it but i cant see what i have to do or what is wrong (not real).
    C&C are most wellcome.
    Re: yacht room
    And there is the rendering? Don't post photos.
    If you like, please share the transparent plastic material in front of the window - very interesting.
      Re: yacht room
      sure Micha;
      actually it is a fake SSS material used as a source for Vray2SidedMtl for both front and back sides.
      now i realise that it needs some time to calculate that. :-\
        Re: yacht room
        Ah, quite simple, light blury refraction and a half transparent diffuse layer. The VfR exported only the submaterial, but I suppose, you use the "blind" material for back and front.
        Rendertime is long, but it looks phantastic real.
        Thank you.
          Re: yacht room
          Good start!
          a few points, since you asked for it:
          -fix the verticals a bit
          -increase render quality (I think lowering noise treshold and upping global subdivs to 2-4 will do)
          -its all a bit too symmetrical, the cushions and blankets. Maybe also add some traces of live: a book, shoes, plant or anything like that.
          You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
            Re: yacht room
            Thank you Gijs and sorry Micha I forgot to thank you earlier :-[
            i had placed some other blanket that were says "some people has just made love here!" ;D but this room must be tidy. i will try what you have told.
            thanks again.
              Re: yacht room
              i have a problem with that blind material it is reflecting things but the source material doesnt have a reflection layer. do you guys have an idea what is causing that?
              here is a test render. blinds have same material and geometry. far one has reflection on it as you can see
                Re: yacht room
                Your material based on refraction, so check the surface normals and is it a volume object? Maybe the refraction act as reflection.
                  Re: yacht room
                  no it is single extrude of a zig zag Pline. i will check the normals but from my point of view this geometry has a 2sided material which means it doesnt matter if the normals are flipped am i wrong about that?
                    Re: yacht room
                    i cant believe that it makes no sense at all but you are right Micha. wouldnt that makes some sort of problem when rendering an animation?
                      Re: yacht room
                      I only know, that the direction of the normal show in direction of the environment and in other direction is the material.
                        Re: yacht room
                        another wip image. i am happy about that one. what do you guys think?
                          Re: yacht room
                          Your renders look amazing, and REAL.
                            Re: yacht room
                            looks good! For final rendering, I suggest you turn on color clamping and sub pixel mapping to get rid of the jaggies near bright spots in the rendering
                            • #15
                              Re: yacht room
                              Thank for advise Gijs,
                              here is a newer version of the last one. it took 3 hr 15 min for 6600x3500 res. with 2x Q6600.
