Optima Renderings
  • Optima Renderings
    Are my renderings photorealistic enough?
    Please answer me!!!
    PS sorry for my english!
    Re: Optima Renderings
    Here there are some other of my renderings
      Great well done, can you upload or post your settings?
      Post some more please?
      http://www.dotsan.com
        Thanks!
        I use Micha's tutorial setings, downloadable here:
        http://asgvis.com/index.php?option=c...derby=2&page=2
        remeber that these settings are good for light panel, if you want you can add a reflection layer with an HDRI for more reflection on the objects.
          Cool, did you change any of the settings, how many rectangle lights did you use and what HDRI map did you use?
          Cheers
          V
            No, I don't change anything of the settings, but you have to uncheck "no decay" on the light panel options and increase the multyplier
              Material testing with "standard cups".
              Just a test to see the reactions of some materials in a particular environment
                This is my last work...do you like it??
                Please someone answer and make me some critics!!!
                Thanks to all to watch my topic!!!
                  Nice work!
                  Why did you use that checker material?
                  I would prefer a more discreet material because the focus is a lot more on the object then.
                  Someone who doesen´t know about rendering can not understand what you whant to show with this sourrounding!
                  The model and material looks pretty nice and the lighting as well, maybe a bit to bright in my eyes.
                  And the last thing what came on my mind when i saw your work was that some depth of field would improve the picture. If you focus the guitars body and the neck gets blurry it might be interesting.
                  Have a nice day!
                  Jonas
                    Hi Jonas, thanks for watching my works!!
                    I use a checker material because the totally white material that I use for test looks too "empty", I think that this backgroung emphasizes more the difference beetween the objects and all the rest...but it's just a personal impression...
                    ..I've tried to set a good dept of field by override the focal distance of the camera, but I don't be able to set it very good...can you tell me if there is a good tutorial for this?
                    ThankS and have a nice day too!
                      Hello,
                      the best tutorial i know is this:
                      http://asgvis.com/index.php?option=c...d=19&Itemid=57
                      made by micha!
                      You should work fine with this...if using a non physical camera.
                      best regards
                      Jonas
                        I all!!!
                        I made a little experiment with DOF and the exposure controll...
                        ..I wanna thank fam_ark to tell me the relative tutorial link!!
                        Are you like it?!
                          I like it ;D
                            Thank you Jonas!
                            If you now some other interesting tutorial, about rendering or still life photography, please tell me... ;D
                            • #15
                              This is my last DOF experiment...
                              Does someone like this kind of works?
