Please Help!!! How to make a Carpet
  • Please Help!!! How to make a Carpet
    Guys, I have been reading all the threads on the forum abotu making a good carpet. But still cant do one. Could someone post a step by step on how to do one?? Please!!!! Thanks. Here is one I did.
    Here is my setting
    solid color with noise
    displacement map w/bump image
    Re: Please Help!!! How to make a Carpet
    i hope this one will work... make the face into group first before applying diaplacement. this technique was shared one of our filipinos here before and it did really work..
    http://www.nomeradona.blogspot.com/
    http://www.sketchupvrayresources.blogspot.com/
    http://www.nomeradonaart.blogspot.com/
      did it work as nomeradona said ?
        it is better..but still the result is not acceptable... :'( please help!! guys...here is the map i use.
          the carpet seems having emmissive material.
          try to do this..
          1. make a simple plane say 100cmx 200cm.
          2. push pull 1cm
          3. choose everything and apply your carpet material (name that material into carpet_diffuse), make it into group
          4. create add material (link material), choose that carpet_diffuse material
          5. bring up the vray sketchup option editor
          6. Under displacement use the following: edge length=2, max subd. 500, amount 1
          render
          enjoy.
            Thanks alot. Nomar...
            This looks much better. I have also changed the overall rendering setting. before I didnt have the emissive setting w/the carpet, btu it turned out some color bleeding there. Very weird!!! but after I changed some settings, now it looks better. Thanks again for your help.
              thats look good art.
                i cant see any of your images artchung??? but i think the problem is solve now...
                hows podium??? by the way im archijdsantos remember? if you got more questions ill will try to help...
                keep it up....
                  C´mon! Share this model! I think i can tweak that and make into some grass!
                  Cheers!
