New Test IES light This one works perfectly.
  • New Test IES light This one works perfectly.
    Hi everyone, i've tested my last post, and scalling down it didn't worked. I dont know why but when we scale that down it burns evrything. but.... this time.... i think i found the solution all credits to somebody on rhino forum, who developed this map, buuut, there was some hard work to convert this to sketchup, i had to change a lot of things, and with no modesty mine were better. hehehe just kiding. You can change the light tipe by the retangular light to add more decay.
    sory for my english,
    the map used on opacity:
    File:
    http://www.4shared.com/file/44942806...ified=31a51396
    PLEASE COMMENT IF U LIKE IT, OR NOT, IT MAKE ME CONTINUE WORKING FOR SOLVE OUR PROBLEMS
    http://andeciuala.blogspot.com<br /><br />Core2Quad Q6600<br />Geforce 8800GT 1GB <br />4GB DDR2 800
    Re: New Test IES light This one works perfectly.
    Second Test:
    Map used on Opacity:
    or:
      looks subpurb.. could you share the skb. file plees..
      regards,
      dwanimations.112desgin.org
      www.DWanimations.org | Makes your work come to life
        hi andeciuala,
        it's look fantastic..
        mind to share, which opacity that you connect the map to?
        thanks
        Regards,
        VD
          hey ande, it really worked perfectly,
          i tested it in my visopt..i am using physical camera so i increase light intensity for around 300-600 and here's the result.
          just a little tweak and it's good to go.
          thanks for making it in default meter unit..
          thanks very much man..
          you're the master of lights...hehehe.
          Viva Las Islas Felipinas!
            hi guis it's evrything there, the skp file, the opacity maps, all u have to do is download de skp file, and on material editor, choose the transparent "M" on difuse, and put those maps on it.
              Hi Andeciuala,
              Thanks for sharing the file, guess i missed it yesterday..
              Ok man, download and test it right away, thanks
              regards,
              VD
                to make the spot with the retangular light all u have to do is pick up my already mapped circle on the file, double click on component select the circle and coppy.,and scale it to fix on your light source. than add a retangular light very small with a high intensity, small on size to decrease the area shadow.
                http://www.4shared.com/file/45208602...ified=31a51396
                this image was made with the retangular light
                  Hi Ande, thanks again.. u rock man..
                  Regards,
                  VD
                    Thank you very much, I know how to do it now. :P
                    I like Vray for SketchUp.
                      LOOK,here is my practise. Ande, thanks again.
                        Hello ande,thank's for sharing this. i'd try to render your skp scene using default visopt but doesn't work it look very dark, can u share the visopt your're using?
                        Thank's
                          Hi, unable the physical camera, or rise up the intensity of the light veerrrrryyyyy mutch.
                            Wow very nice one, it looks great. I'm so happy to help you all.
                            • #15
                              I think,if you all want to use this kind of IES with VraySun,the intensity of your Rec Light must be around 12000 - 50000(like the way the Emmissive layer do work)
