Interior: Living room part 2 - WIP
  • #31
    would u be kind the share the two tree mesh of yours.
    if it is a ugly reguest ,then pls forgive me.
    thanks.
    • #32
      Dman3D:
      Did you actually model those trees or is it one of those 3rd party plugin trees?????
      They look awesome....I am using speedtree and it doesnt catch the light as well.
      Regards Martin
      • #33
        mzmeskal:
        Dman3D:
        Regards Martin
        The ficus in the back corner is from Xfrog made by GreenWorks,
        the philodenron was modeled by hand (the one closer to the camera)
        The philodendron is climbing a stump or piece of driftwood, whichever
        you prefer to imagine.
        I have speed tree as well, problem is they tend to look artificial.
        XFrog is more or less a procedural modeler for plants or any shape for
        that matter. That ficus is from one of the extra pre-built libraries.
        andre:
        using displace/waterlevel seems like a good idea, but if introduces too much new geometry, you should use mesh-leaves. refractionmaps are terribly slow, whereas vray doesn´t seem to care about another 100000 polygons.
        from my experience with vray, modeling things instead of mapping the best approach.
        Agreed, VRay does not seem to care how big it is in polys, just nooks and
        crannies bring you to your knees. I would use geom leaves like the vine
        but it would require shredding the tree model apart and replacing each
        one with a geom leaf. Not sure I am up to that challenge, I would go insane
        first. Think I will tolerate the transparency errors for the time being.
        I need to model some more leaves/vines. Been using the same ones
        over and over. Perhaps I will mix up the scale and map.
        Same ones I used here
        http://www.chaoticdimension.com/foru...pic.php?t=3840
        are on the coffee table and left vine
        "It's the rebels sir....They're here..."
        • #34
          hey do you know where i can get those chinese letter textures? im tryin to find one for a poster im tryin to render but no luck. Could someone direct me? thanx
          • #35
            I got the ones in this image here
            http://www.art.com/asp/collections/s...13/posters.htm
            art.com has lots of good stuff.
            cheers
