my very long render time 85 hours
  • my very long render time 85 hours
    hi this my recent render....
    it took 85 hours to complete...
    i used the default visopt and ticked off the hidden lights
    pls any suggestion to reduce the render time...
    and wat i did wrong here..
    thx in advance
    my blog containing some of my works<br /><br />http://aufialwi.blogspot.com/
    Re: my very long render time 85 hours
    What's the actual version of VfSU that you're using? At one point our defaults used DMC, which would explain the incredibly long render time.
      It's pretty much impossible to give you visopt advice without anything to go by other than an image and "default visopt". 85 hours is extremely slow for VRay (about 85 times too slow for such an image) so there must be something seriously wrong with your visopt setup. Post screenshots of your visopt settings and you'll likely get a bunch of advice in no time.
      Nice image BTW, though those red trusses are distracting and don't fit at all with the rest of the building IMO. :-\
      SU 2018 + VfSU 4.0
        owh that trusses intend for some shading but since my tryout turn out to be 4 days to complete..
        i have lost my 'passion'(forgive my english) with this model
          and another to add some more..
          is it the amount of rectangular light used do affect the render time?
          bacause i use a lot of it at this model..
          each lvl i used more than 10 set of rectangular light but they r all identical
          except the yellow 1 and those glaring 1
            Check out this thread about lights and render times: http://forum.asgvis.com/index.php?to...28175#msg28175
              thx a bunch thomthom..
              that will answer all of my problem....
              so use the rec light with stored with irradiance shuld greatly reduce the amout of time it take?
              so with the visopt setting that i put here
              the irradiance map's HSph. subdivs and smaples shuld be increase..
              so that there is no splotches on surface?
                I never use DMC, try switching your secondary engine to Light Cache and you'll see your render times drop dramatically. Also change your DMC Sampler Adaptive Amount to 0.85 instead of 1.
                Other than that your visopt parameters look fine.
                SU 2018 + VfSU 4.0
                  thx a lot jackson....
                  it is much more faster
                  im very delighted
                    also change the number of samples.
                      in my humble opinion Irradiance Map and Light Cache are the best combination for fast and quality renders, it would be good got switch to those, or get a pentium :P hahaha just kidding
                        what AMD no good?
                        T_T
