BTH-recent render 2...
  • #16
    Re: BTH-recent render 2...
    great man can you post how long you render the image and what visopt you use .The coach looks greate is it made by you.Great man keep going
    • #17
      bechura:
      average time of each image is more than two hours.
      this is the basic settings to use for this scene (version 01.05.30)
      http://www.mediafire.com/?tzik1aqmmzi
      http://www.suvn.net
      • #18
        excelent renders, specially the fireplace ones, whant type of lighting did you use?
        • #19
          NEKTARES:
          I used map + transparency for fire and use a omni lights (with decay = inverse, subdivs = 15 ...).
          I do not use "emissive" because lighting is not well.
          http://www.suvn.net
          • #20
            thanks man i will use your settings ,your renders look so good .
            • #21
              Originally posted by tranganhhp
              40th: you want to share my leather sofa?
              I really like the cushions on the sofa, can you share them? (that was my question)
              www.Top3Dstudio.com
              SU 8
              VfS 1.48.89
              Win 7 64-bit
              • #22
                thats right! emmisive is not good for lighting, i think the same, because it burns where its close and its weak when its far, i think your render is so well modeled (plus great textures and light) that all together deliver an amazing result, excellent work, thanks for the tip on the fireplace, if you used just 15 as a value i assume you are using standard camera and controlled point and rectangular lights, am i right?
                • #23
                  NEK:
                  I use the Physical Camera. light source is HDRI. omni lights in this scene using multiplier = 7-10. because I put F-number = 2 should be enough light intensity.
                  you can see my settings http://www.mediafire.com/?tzik1aqmmzi
                  http://www.suvn.net
                  • #24
                    This scene here (includes all materials, model and settings)
                    http://www.mediafire.com/?fnwmzzrnymg
                    http://www.suvn.net
                    • #25
                      Wow, you are so kind. Thank you for share your model. With us.
                      Best
                      • #26
                        Thankkkkkkkkyouuu very mUch for your kind
                        I will using it to do my best project.
                        • #27
                          It depends on what type of lighting your talking about. I think it can be used just fine for subtle lighting, for instance in a night scene with ample lighting. This would add to the effect of the fire if it can be used in this scenario. But, for lighting a scene, you are right, it should not be used as a lighting source. This would produce unwanted results and artifacts.
                          Justin
                          • #28
                            :O these are actually insane! I thought the first picture was a photograph! Incredible, certainly somewhere I'm aiming for, in about 40 years :P
                            - Robyn -
                            • #29
                              I don't understand, where are the renders? by the way a newbie here
                              • #30
                                maybe in your location photobucket is block
                                http://www.nomeradona.blogspot.com/
                                http://www.sketchupvrayresources.blogspot.com/
                                http://www.nomeradonaart.blogspot.com/
