"Es ist nichts falsch, was passiert ist, dass es nicht so professionell wie Sie denken. und dieser Beitrag ist nicht zu diskutieren.
"Il n'y a rien de mal, ce qui se passe, c'est qu'il n'est pas aussi professionnels que vous ne le pensez. et ce poste n'est pas pour en discuter."
"Non c'è nulla di sbagliato, quello che succede è che non è professionale quanto si potrebbe pensare. e questo post non è quello di discutere questo."
free 3D model of S533r chair by Mies van der Rohe:
I shared this model for you, so you can download it in NURBS: http://www.flyingarchitecture.com/s5...-van-der-rohe/ (The targeted restriction in the use of materials, elegance in the lines and transparency in the effect are the characteristic properties of the S 533. It owes its special comfort to constant elastic flexing. This effect results from the fact that Mies van der Rohe conceived the front part of the tubular steel frame as a big bow made of spring-hard tubular steel. While most of the designs from the 1920s were rather simple and functional, this chair clearly communicates the signature of the architect: his design combines functionality and comfort with timeless aesthetics. The chair was first presented in the Weissenhof-Siedlung in 1927.)
excelentes renders...
esta muy bueno el mapeo. felicidades
gracias por el modelo, justamente estoy a la busqueda de una textura similar para muebles de jardin.
saludos!
