Nice setting, clean and sharp. It has a very masculine feel. Love the flooring and the choice of colours and materials.
I think the concrete wall (if it is concrete) is too smooth and glossy and those spotlight reflections on it don't feel exactly right, but I'm a junior in Vray, so I might be wrong.
Composition-wise the image is a little unbalanced, the left side has too little details so it looks a bit flat and unfinished. Also you probably should have made the room smaller, I can guess the proportions by the reflection of the shower and the there's too much empty space in the middle.
But I like the overall feeling, so keep up the good work!
Thanks for the comments
The wall that you refer is kind of gray marble.....and yes this is to big for a bathroom, but I only do for un job experience.
Hey there,
it's a comfy mood you've created - well done!
If you're up for improvements, here are my two cents:
- I agree with iamiri: on the left side you could add some more details. I suggest you put some background in - having a nice panoramic HDRI that you can see through the window will increase what I'd call "real feel". Even when using frosted glass, you'd get a slight indication of what's behind. In addition, you could insert some decoration (driftwood on the windowsill, a vase with some branches or twigs, a picture, a bottle with essential oil and some straws or the like).
- Great attention to few details really makes this one complete. You could put some typical sanitary products on the shelf and in the cups/containers: toothbrushes, toothpaste, shower gel (eg. on the floor next to the shower, so that you can only see it through the mirror), towels. But not too many!
- Let the toilet paper hang down a bit, give it a little twist and some texture bumps to make it look real!
- In the real world, furniture isn't always placed perfectly aligned - copy that in your scene!
- As already said, the highlights don't look perfectly right.
- The bench could use a better metal material for its feet, as well as a little more illumination.
- The "kind of grey marble" shouldn't repeat, maybe you could alter the texture in Photoshop.
- What kind of material should the white wall be made of? If it's plastered, show it with some noise (very low multiplier) in the bump or displacement channel!
- Use depth of field to blur the reflexions in the mirror a bit.
- Increase subdivs on blurry reflecting materials (esp. floortiles) and/or in the options menu.
Don't worry, your scene looks pretty decent already!
Hey there,
Cheers,
Matt
Thanks for the "big" tips
I will try to have more carefull in the next works, because I know that the scenne it's pretty but whithout "life"...sommetimes in my job "giving life" to the scenne is waste of time, if you know what I mean, but my "outside job" is try to do what you said, always looking to improve... ;D
Nice pictures. In Today’s time designs of bathrooms varies from practical and useful to luxurious and lavish. People make use of so many different accessories to make their bathroom look beautiful.
Shower pod is one such bathroom accessory that is becoming very popular. It comes in different varieties. It is designed to save space and hold personal shower accessories.
