More VRay Displacement
  • More VRay Displacement
    This little guy started life as just a four sided plane, clipping is used to form the outline.
    Eric Boer
    Dev
    very clever
      Amazing! can you explain it in depth?
      Thanks
      Gonçalo
        Here is the setup:
        I painted the displacement map over the photo that I referenced (the background should be black).
        3D displacement, amount 9.6, Use water level on, water level .2, face subs 128, Use object mtl on, Keep Continuity on.
        Reference.
        Still needs some work
        Eric Boer
        Dev
          amazing, if you imagen how much work it would be without that tool.
          but still think we need better UV-Mapping of displaced objects and DIRECTION to displacement like MR and PRman.
          regards,
          robert
          I'm registed believe me! Just miss that logo.
            Wow, very cool! I once did a face with the standard Max displacement, a few years ago, but that required too much detail. Things have changed now, as RErender proves. Very nice.
            Cheers,
            Metin
            Sevensheaven.nl — design | illustration | visualization | cartoons | animation
              By the way, what do you exactly mean by "clipping is used to form the outline"?
              Cheers,
              Metin
                What does "use water level" do? Is this how you achieve the clipping?
                  Yes, Using water level @ .2 tells the modifier not to create the part of the displacement that is below the threshold, So the parts of the map that are black have a displacement of 0 which is clipped because it is less than .2. This also works well on any opacity mapped object like a Tree card, leaves, or ...
                  Eric Boer
                  Dev
                    Aha, it all becomes less murky. Thanks for that, RErender.
                    Mark
