Child Care
Child Care
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
dummies, good idea... I'll try that.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Glorybound,
There's nothing wrong with the people you used that some artistry couldn't overcome. Just channel Rembrant or Maxfield Parrish or some other painter and add the shadows where you would expect them to fall. Burn, dodge and sponge where they would. The people are just a starting point to exercise your photorealistic/impressionistic skills on. Ground them with shadows on the ground (a trick to this is to make a copy of the person, desaturate it, bring the contrast down to black and then distort it into a shadow on the ground. Give it "multiply" property and then make it the appropriate transparency) A big part of any touchup is to know where the light source is and then shadow the people based on where you would expect the shadows to fall. If you need sources of inspiration or reference, Getty images is packed (but expensive to actually use ) Bigstock photo is a lot cheaper and has a lot to look at. But both are free to just browse.
Really, if you want to know how the master painters handled things, google them and check out their use of light and dark.
mh
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by KAKTUSDIGITAL View PostI think you did a really great job on that stone material. re: the sun behind the camera.. what can ya do hey?Last edited by glorybound; 27-09-2011, 08:53 AM.Bobby Parker
phone: 2188206812
- Windows 11 Pro
The only problem I have is, even the best ones I have seen, still look like they were cut/pasted. I'll do my best, and can only get betterBobby Parker
phone: 2188206812
- Windows 11 Pro
Whoot! I got some feedback.
The rendering looks fantastic. We are super happy. I assume kids etc. are placed later. I made a few comments above, but overall it is awesome.Bobby Parker
phone: 2188206812
- Windows 11 Pro
its true, unless you get the people shot with the correct lighting, from the correct camrea angle, and have them beautifully masked, its always possible for a trained eye to spot the difference, however good you are. but clients usually dont have that trained eye.. and its possible to get a pretty good result with a bit of care.
good feedback btw
