i think the file is so big because of all the hidden objects to speep up rendertime you can lower the samples of the vray shadows (120 to 50 f.e), a lower AA (now its 1/3) and a lower irradiance map (maybe medium instead of high). and you can try max density of 1 and search radius of 2-5. these things will speed up rendertime but maybe looses some details. as you want......
your render is very very nice. I'm a finalrender user and I'd like to try to render the same scene with my plugin. Could you send me the file via email please? I have max 5.
Silver, também trabalho com imagem para arquitetura, e queria saber se vc realmente acha necessário utilizar "photom map" no lugar de "direct computation" Consigo tempos em torno de 2:30 (com o cálculo) para cenas como essas (sem muita reflexão e razoáveis objetos no espaço.
Vi um tópico aqui chamado Life's Swell e utilizo parametros muito parecidos, acredito ser prático, mas como vc está passando pelas duas técnicas, o que vc está achando dos photom maps?
Ah! Achei o modelo de sua cama fantástica! Vc a fez? Comprou ou conseguiu em algum lugar?
hello notoiara, thanks mate, but i wish in the next job i get some improvements with phtons thecniques, because , as you can see... some materials problems are there...
hello theo
about your question, i will have the answer only at the next job, because this file was not set up correctlly to be used with photons... but i think that it must be a good thecnic, considering that almost good users as gonçalo, metroberlin and everyonelse that i could not say now are using this thecnique. This is thje reazom for what i im so insistent in learning it.
O lance é : se os caras que são tampa usam... deve ter algo de bom neste angú, sacou mano, hehehe
