American Mansion
  • #16
    yes. I do this with almost everything I do.
    Originally posted by deflix View Post
    You can enhance fine detail in plants and grass by adding an AO element. Use a Vray extratexture element, with vray dirt set to AO and subdivs 32 or higher. do a few with different distances. Once rendered pop the AO pass on a layer in Pshop and blend using Multiply blend mode. Enhance the effect by duplicating the layer in Pshop and mask out where necessary
    Cheers
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      yes I can see in the last image actually looks great btw!!
      Immersive media - design and production
      http://www.felixdodd.com/
      https://www.linkedin.com/in/felixdodd/
      • #18
        Bobby, what trees are you using in here?
        • #19
          I usually use i-Trees, but for this one I tried some Evermotion trees. I read here, that Evermotion trees are good for up close, but I don't like this one. If I had to do it over again, I would try my i-Trees. The bushes are from i-Cube.ru.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #20
            I kind of like the large foreground tree. It frames things nicely. Very moody. Looks like its time for a cocktail there.
            • Dual 3.47 ghz Hex Core Xeon CPUs; 96GB Ram; SSD Drive; 3dsMax 2020; V-Ray; Sketchup 2020
            • Love these Plugin/Scripts: ForestPro, RailclonePro, Soulburner, Populate Terrain
            • #21
              I think the placement is good, it's just that the tree is very detailed, and it's muddy.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
