how can i illuminate larg scenes with vray
  • how can i illuminate larg scenes with vray
    hi guy ,,
    i have a big project (bowling center )
    i dont now how to illuminate it coz it too larg space and it took alot of time in the rendering testes ,,
    how can i put the lights onto the scene i want indoor lighting
    this is the top view of the scene
    and this is the lighting setting
    and this is the test
    can u help me in this concept plzz
    i like to light large indoor scenes with self-illuminated objects at the ceiling, its faster than having a lot of lights.
    you will loose some shadow detail, so you can use an extra light for foreground objects in order to lock them to the ground.
      its a bit of a cheat but you can have one very large vray light half way between your floor and ceiling and have it at a very low level e.g 0.5 or lower then have your normal light as they would be..... works great for me.
      Natty
      http://www.rendertime.co.uk
        nice trick, natty.
        i will try that one.
          glad to hear I'm not the only one using large VRaylights and self-illuminated objects..
          example:
          [self-illuminated objects only + 1 direct = very fast rendertimes! VRay rulez when using this method]
            wow, u should explain more bout ur method, bratwurst
            which one is true, 1 vraylight or 1 direct light?
              I use large self-illuminated boxes checking "invisible to cam" Simple but effective. Placing them is the tricky part, you dont want any collisions or extreme bright areas.
              1 direct for the sun.
              Cheers!
                hi guys and thanx so much ur reblies
                natty do u mean that i make one vray light that can cover all the space - i think it will be too big - what about the shadows and what about the maltiblier what about the over bright aries,,, pleas tell me in details
                bratwurst very nice work ,, wow ,, tell me more about the self elluminated objects do u mean that i make the cieling self elluminated or - and what about shadows and the cieling ovber bright or u mean meake some objects let say boxes and give it a self illuminated mat - where i but them over the cieling or under the ciling ,, am sorry i have abig problem with this work
                and thax very much
                  the second try
                  hi guys
                  this is the second try on this concept i made one very larg vray light and mak it with low multiblaier and this is the result
                  thanx iam waiting 4 ur advices
                    hi
                    do you like the result ?
                    Natty
                      I dont think it looks too bad. Its a good start to a good uniform lighting approach. Add some more direct lighting where its needed and I think itll come out nice.
                        try to play with gamma ( 1,5 1.8 ) for your general lightning
                        Vince
                        Architecture & design Sàrl
                        global solution for architecture
                        www.architecture-design.ch
                          hi guys ,, thanx so much 4 trying help me
                          natty ,, i think the result not so good ,, what do u think about it ??
                          i show try with that percydaman and thanx
                          vince_1972 from where can i control with the gamma
                          hey natty what do u think about this try ,, i used the object lights as bratwurst talking about
                          and this is the test image ,, i think it is more usable but it need more tweaking coz i had over saturated areaies and when i put the cieling mesh it coused some pionts of over brieght ,, the quetion is how can i control with this boxes lighting ,,,
                          so sorry for my bad english
                            another try
                            hi
                            this is another try with box self illuminated
                            i used one larg box to cover all the scene ,, to go far away from brighten areaes on the cielng ,, and i make for defuse an output white color
                            but ADv. there is no over bright areaies , the scene has anice lighten
                            disadv. .. i lost the shadows ,, i had abad look for the cieling ,,, some saturated areaies on the wooden graund
                            whats ur advice on this shit ,,
                              You need some more direct lighting to create some good shadows, which will help anchor those chairs to the floor.
