House Rendering - pool side
  • #16
    So here's the same trick applied to your 1st image:
    I think your 1st image modified is the winner (well just my opinion anyways)
    Kind Regards,
    Morne
    • #17
      yes, agreed!
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
      • #18
        I dont like the soft glow.
        • #19
          I'll render it out again this weekend and try it again
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #20
            As usual I don't like the razor sharp corners you have on all your stone textures.
            • #21
              As usual its a tight tight crop! The left side of the house barely has room to breathe.
              • #22
                Here is a quick turntable animation
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #23
                  This suck BIG time! You should turn the other way Just kidding. It's looking good. Looking forward to the final
                  Kind Regards,
                  Morne
                  • #24
                    I think the sun should be more like noon time.... Casting shadows over the pool is not good idea, the camera maybe needs to be a little bit higher to see more water...... And the glass doesn't look like maxwell, it looks cheap!!!! ( It's a joke).
                    show me the money!!
                    • #25
                      Well, Flini2004. You can just kiss my glass! I am rendering this out again, and have made some adjustments, including the sun angle. QUOTE=flino2004;595968]I think the sun should be more like noon time.... Casting shadows over the pool is not good idea, the camera maybe needs to be a little bit higher to see more water...... And the glass doesn't look like maxwell, it looks cheap!!!! ( It's a joke).[/QUOTE]
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #26
                        I am working my butt off on this one, and I am not getting anywhere. I think it's because I can't render it out at a high enough resolution, so my darks are really muddy. In the original I wasn't seeing wealth, and it's one expensive house. So, I made some tweaks, and here it is. I'll see if I can tweak some settings so I can render it out higher.
Name:	pool side gazebo.jpg
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #27
                          [ATTACH=CONFIG]16294[/ATTACH]
                          Much much better! look at all that open space! Good materials and definition too. The tree on the right is looking kinda weird (blurred in PS?) and the grass could use some colour variation/highlights. Other than that, great improvement.
                          • #28
                            Looks much better. I think you're overdoing it a bit in photoshop however
                            Also, I would take out the fence in the foreground and maybe add some flowers instead. Agree with the tree on the right, something seems off there. Also, I don't think your sky fits in the scene
                            Kind Regards,
                            Morne
                            • #29
                              the sky is from the HDRI, so that should be good. My main issue is render times are astronomical. When I get those down, I can work on composition.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #30
                                what is astronomical and what res you doing it?
                                Kind Regards,
                                Morne
