House Rendering - pool side
  • #31
    6400 x 3200 - the pre-pass and render times would have been around 26hrs.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #32
      You can usually ignore the initial estimates for the prepass. Often, espesially with displacement or lots of proxies, my LC calculations shoots through the roof initially to something like 300 and something hours and just keeps getting higher. But then it suddenly drops again and rarely it takes longer than 10 or 30 minutes
      Just INCREASE your settings. You'll see how cool this is. Set your HDRI dome light's subs on 256. Your materials between 32 and 128 depending on glossy. IRmap on medium preset and just change hssubs and inter samples to 60 and 40. LC defaults but maybe 2000 subs and tick glossy rays and enable pre-filter to between 50 and 150
      With these settings that scene at that res shouldnt take anything more than 4 to 5 hours
      EDIT: and dmc should be min 2 and max somewhere between 32 and 50, check your sample rate element to get the optimal max setting (it should be mostly blue with well defined edges, try to get as little red as you can without loosing the edges)
      noise thres default
      Kind Regards,
      Morne
      • #33
        I'll try it, thanks.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #34
          Nope! 1 1/2hrs later and prepass says hours left. I zipped everything up and I'll upload it. If you want to play, I'll post the link. http://www.sendspace.com/pro/dl/ukxs6i
          noise thres default
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #35
            Thanks, but a 1.8GB file will take couple of days to download...
            Kind Regards,
            Morne
            • #36
              I downloaded it. Will try to take a look today.
              • #37
                I turned the stone displacement off and cranked up the bump, which at this viewing distance seems to work fine. I rendered out 3200 x 1800. and it took 3:46:20.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #38
                  You had your stone displacement set to 3d, which really slows things down. 2d is much faster.
                  • #39
                    yes, but I need the corners to weld. I am posting an update soon
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #40
                      Okay, here is an update. I didn't render out at a very high resolution, but it's just for screen anyway.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #41
                        I boosted the pool blue, so you can tell that it is water.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #42
                          Now this one I like. I think it works especially well now that you've faded that gazebo into the background and put more focus on the house.
                          • #43
                            Yes! it's nice to have a plan . I worked hard on composition and I also tried a few new techniques - I love light select on the vraysun - awesome!!!
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #44
                              I still like this bleach look... is it better?
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #45
                                A little warmer, but hopefully not overdone.
                                Bobby Parker
                                phone: 2188206812
                                • Ryzen 9 5900x CPU
                                • ​Windows 11 Pro
