one try
  • one try
    http://www.flickr.com/photos/64493973@N ... /lightbox/
    I have a lot difficult with texture the wood seems too fake i'm not able to trim with accuracy reflective, glossiness, i used rheinard with burn 0.6 and gamma out 2.2
    Any suggestions?
    Re: one try
    I could suggest to add some warm interior lights like IES or smth - it'll give some depth to the scene.
    Use glossy reflections about 0.85 on wood - it'll look better.
    You could share the scene - may be someone help more =)
    andrei.izrantcev@chaos.com
    Support Request
      Re: one try
      Thank you Andreji but i 'd like show the scene illuminated only by external light.
      Seeing the scene of BBB my question is:what makes it so special this scene?Sure the modeling is perfect the texture is high quality high resolution the material defocus ecc,the subject ,but i think i don't understanding something about the light:color mapping? saturation?
      Any way you suggest 0.85 glossiness with reflective set to one?
        Re: one try
        Me too ) Have no idea how he did that level of realism =)
        Reflection color should be dark grey, about 0.2-0.3. It could be 1.0 if you combine it with Fresnel turned on - it could also give some interesting results.
        Support Request
          Re: one try
          this comfort me...i 'll try at soon the settings suggested and when i aproximate to the final scene i' ll post......... thks
            Re: one try
            http://www.flickr.com/photos/64493973@N ... /lightbox/ the experiment continue....
              Re: one try
              http://www.flickr.com/photos/64493973@N ... otostream/
                Re: one try
                The second one is pretty cool!
                Support Request
                  Re: one try
                  Thks but i m not able to use portal light when i try ti use it the render become over exposed do you think simple portal lights is the way to add light in the environment?
                    Re: one try
                    They shouldn't change the lightning too much, but anyway if this happens simply use physical camera settings to tweak it.
                    Support Request
                      Re: one try
                      pleas attach your image
                      our country president don't lent our see flicker
                      flicker is filter at my country
                      I am Programmer,I have no life
                        Re: one try
                        are able to use tor?
                          Re: one try
                          tor , freegate and ultrasorf dont work at my location
                          i have one way and it is buy a vpn acount
                            Re: one try
                            In wich way i can attach the image?
                            • #15
                              Re: one try
                              my friend
                              you can use this way to attach a image
