one try
  • #16
    Re: one try
    this is my try
    • #17
      Re: one try
      that is good kitchen so good my friend
      but you desable shodows ? i cant see any shodow and do you know standard parquet size is 7.5 * 1 inch if you rescale parquet uv to smaller your render will too realestic
      i love your work
      thankyou for attaching
      I am Programmer,I have no life
      • #18
        Re: one try
        excatly ,i'm not able to understand the shadows don 't appear the hemi+hdri seem dont generate shadows.
        • #19
          Re: one try
          ops desable (means disable ) sorry
          i dont work with your way on interior design but i know if you adding soft shodow under table under chair and betwin edges your work upgrade to more realestic
          • #20
            Re: one try
            eh eh i know but i'm not able i hope some suggestion come.......
            • #21
              Re: one try
              Depends on the quality of hdr, both on size resolution and on luminosity or color range. Sometimes the luminosity of lights that depend from the sun, that in some hdr image are clamped, due to over exposed source photo. Also check the subdivision of hdr, normally I set it to 64-128 to have good "shadows".
              Another tips, check the colorspace of the hdr bitmap, srgb or correct the gamma to have hard shadows, but you have to pay attention to final color mapping.
              • #22
                Re: one try
                but do you think is possible thath the quality of hdr affect so drastically the presence of shadows?Any way the hdr is an high quality i think ( bought on cgskyes)
                • #23
                  Re: one try
                  some one can help me to avoid the great pixel in the shadow in the wall behindt he bed?
                  • #24
                    Re: one try
                    so good
                    i like your bed :d that is so realestic
                    if you added a wall light and 2 paint frames and add a carpet center of your room i think your room get the best interior design award
                    so good man thank you
                    • #25
                      Re: one try
                      It s just a test i m modeling some books and a lamp and other....
                      • #26
                        Re: one try
                        i try to reach photorealism but something is wrong,may be colormapping how many factor affect to reach phorealism except the perfect modeling?
                        • #27
                          Re: one try
                          another experiment i found a problem with sss material of the leaf
                          • #28
                            Re: one try
                            I'm not sure that it's a good idea to use SSS for such stuff like leaves - use Two-sided material. Two-sided material is also suitable for cloth like curtains.
                            andrei.izrantcev@chaos.com
                            Support Request
                            • #29
                              Re: one try
                              i tought the sss was a good idea because in nature organic material have a behavior like sss mat, anyway the shot was done with brute force 60 subd with AA 4 min 16 max.
                              But i read in a site that the max that you can obtain to vray is bf subdivision on default and AA 1-100 , i also read in a post of bbb3 that he used bf with 60 subdivision.
                              In substance....i have a great confusion!
                              • #30
                                Re: one try
                                IM +Lc
