Major 'Butcher' Achaja, my princess
Nice, but whats the issues with hair?
There is a "Fur" panel with "Width" parameter - doesn't it work for you?
You have slightly outdated V-Ray, we fix this a year ago or smth =)
Thank you
In fact only bacground image is the sky. Pillars and "ruins" are done my.
About scratches, i have tried to mix some image textures using dirt as factor, but when i plug this into bump slot, dirt caused some strange thinks. Anyway, recently I have update my vray to niglties build and I am going to check if it still happpens.
Ok! Also you could use vertex paint to paint the dirt edges and parts you want to mix, and use a node call Mesh Vertex Channel, it will allow you to use vertex paint properties and use it as a factor to mix different material with the Layered node.
greetings.
