You have to reduce the Influence, which is the balance between path following and letting the liquid do its thing. Also, if the tube shape bothers you, you need to also reduce the Rotation speed.
I have an old test scene I did when the body force was first introduced to the nightlies. The scene is on there to download if you want to see how its generally done Obviously it is fairly old but I think the same idea will apply to the more polished version 3
Also a simplified version of the scene from the video will come with the install - now the samples go into the 3ds max folder, in the /scenes/PhoenixFD/samples directory.
