Help with indoorscene
  • Help with indoorscene
    Hi.
    I have done the same like the tutorial(room1.exe) from natty.
    I have usw two VRLights and the VRay settings from the tutorial. But i miss the sunlight and i think its a little bit to dark.
    How i make a realistic light for this scene?
    file
    send me the file..ill do my version and mail back to you.
    Reza Bahari
    visual3d@streamyx.com
    013-3428162
      Yea.
      I`m at work now. But at the evening i send you the file.
      But plz eyplain meh what did you do after. Because i would understand it.
        hi
        you could just add a direct light as sun and increase the first diffuse bounce, that should do it ... and once you start adding your materials the room will start to light up anyway.
        Natty
        http://www.rendertime.co.uk
          Which color and which mult.?
          sorry, i`m a german boy. Don`t understand, what do you mean :/.
          I think i adding materials at the end of the next week.
            go for a yellow, orange direct light around 2 - 4 multiplier.
            increase your Primary Bounces for the IRR map just so the light goes a bit further into your scene.
            Natty
              I find the result sucks .
              Here is the picture:
              And here are all the settings...
              VRay:
              244.5K
              VRayLight(2x):
              DirectLight(Sun):
              I hope someone can help me. I my first time to light a scene...
                well if you think it doesnt look right you need to change it... look at the light coming through a window and say to yourself what colour is it. im afraid you cant just ask how to set up a perfect scene you have to play and learn. put more white in the light and just experiment, thats the only way you are going to learn.
                maybe put a white material on the walls ... grey is not good for bouncing light.
                also you have shadows off on your sun ??
                Natty
                  First try to texture. What do you think?
                  With the sunlight... don`t know. I think i modeling the scene and after i texture it. After we look again with the light
                    1st try to move the sunlight direction to shot the desk and the cabinet
                    2nd try to up the first and secondary bounces multipliers
                    3rd sun light is too yellow... turn a bit to red an white
                    Hope I help you
                    bye
                    Jose
                    www.plan9-net.com
                      I have done the three things. What do you think now?
                      I have a problem with the aquarium. I have put a VRayLight into it, but the light is only in the aquarium. It don`t shine out of the glas. The light haven`t got any effect on the room. So whats wrong there?
                      I asked two friends, but they aren`t used to work with 3D. They find, that the picture 13 is realistic, because its darker and they like the shadows.
                        I think it can be fixed using Standart material with a VRayMaps in a reflection and Refraction slots instead of VrayMat...
                          sounds like you have to make sure you have Affect shadows ticked in the vray material roll-out, then the light will go through the glass
                          Natty
                            Yea, the light goes out now. Thx.
                            But what is wrong with the glas? I have done a quick render and there are many black points on the glas ^^.
