The Cascades
  • The Cascades
    Here, is an elder care that is being finished.
ID:	882714 Click image for larger version
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Nice work Bobby
    I like the using of DOF as I rarely use it in my interior projects .
    Just a small thing about the ceiling I think the bump scale is a bit too big
    and for these splotches on the dark areas , additional weak light could help to clean it up or u can go with the BF route
    Cheers
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
      Thanks. I am noticing some noise; I'll work on that.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        The interior designer insisted on a wide angle lens. I think this one will not be wide enough for her, because it doesn't show everything she is doing, but any wider looks awful.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          To get a clean render, this bad boy took 18 hours, and I don't have a clue why. Anything other than universal had issues. Good grief!
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            I looked at it as a thumb and it was a little dark, so I lightened it up.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              It's a really tall space, I like that you are capturing it quite well but I would use a "tilt-shift" lens and keep those vertical lines straight and cut a bit away from the floor as it is the least interesting thing to look at which is currently taking up about 25% of your image space.
              Maya 2020/2022
              Win 10x64
              Vray 5
                tilt-shift, interesting. I'll give it a try. I agree with showing less floor, too. Thanks!
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Some cleaner versions of the two other views.
Name:	cascade bistro.jpg
ID:	858376Click image for larger version
Name:	cascade Reception.jpg
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
