The Shed
  • The Shed
    I am not sure about the design, or the illustration for that matter, but here is the first iteration.
    The architect did his own, which I thought I would share. I only share because, in our initial correspondence, he said that they do their own photorealistic renderings, however, they needed it better. The point of the story is, we need to sell with pictures and not with words. Cold calling or emailing, without proof, photorealistic means different things to different people.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Very good Bobby, only thing I would add is Chamfer to the sidewalk edge, but that is minor. Great job.
      Thanks. I am trying to randomize the boards on the fence, however, I con't figure out hot to assign random material ID's. Any clue?
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I might have found something:
        http://www.scriptspot.com/3ds-max/scripts/randommatids
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I would take the runners out of there....they don't even look like they are running, they are posing...they rendering of the building looks very good and wild grass needs some work as well
          show me the money!!
            I just purchased the male runner . I'll work on it.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              modifier called Materialbyelement
                I'll check it out, thanks!
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  an update
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Nice!
                    Just check the boards. The angled ones and the ones on the right are fine, but the left ones have some uv issue
                    Kind Regards,
                    Morne
                      How I missed that, I don't know. There is no preview using multi texture, so I need to do small render regions to check things.
                      Bobby Parker www.bobby-parker.com
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Okay, fixed the fence mapping and worked a little more on some textures. Also, I went with a little bit of a summer feel; I am not sure if that worked. I am not sure if the clients want adult trees, or younger trees; that'll make a big difference.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Some updates. I still need to add detail, but that'll come after my client sees the progress.
Name:	the shed day.jpg
ID:	858934 Click image for larger version
Name:	the shed night.jpg
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Dark one seems a bit foreboding, the light fittings illuminate quite small surfaces so you're not getting much task lighting along the ground, even for safetys sake. Are there no street lights near it?
                            • #15
                              The building on the left appear to have suffered some blast damage in the evening shot.
                              MDI Digital
                              moonjam
