The Shed
  • #16
    Bad shadows, I'll have to fix that. I was having issues with IES lights; they simply didn't work. No matter how high I set the intensity, nothing happened.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      Is it just shadow? It looks like a bit of sky is peeking through sections of the roof
      MDI Digital
      moonjam
      • #18
        It does look like it's tree shadows from an IES. Try and override the shape, choose circle and give it a 4-6" diameter. See if that helps. Maybe even larger? It should help soften the shadows.
        Brendan Coyle | www.brendancoyle.com
        • #19
          Hehe I'm seeing the same thing as AJ
          Ditch the IES and just use a normal plane light in spolight mode
          Kind Regards,
          Morne
          • #20
            update on the day shot
Name:	the shed front.jpg
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #21
              Bobby check Bertrand road tutorial http://bertrand-benoit.com/blog/naka...road-tutorial/
              Luke Szeflinski
              :: www.lukx.com cgi
              • #22
                Crazy amount of steps. When I have time I will go through it, my roads do need work.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #23
                  what do you mean a plane light in spotlight mode?
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                  • #24
                    I mean a normal VRayLight "Plane" or "Disc" and then enable the directional parameter. Default is 0.0
                    Try a value of 0.7 or maybe 0.6. You can also switch on the preview mode to "selected"
                    It basically angles the beams from the lights inwards, like a spotlight or flash light. Works well for this kind of situation
                    Kind Regards,
                    Morne
                    • #25
                      Some updates. This one is tough. I don't know if it's just the design, my perspective, or a combination of things. The client likes it, so I guess that's the goal. I gave to do a courtyard view, which I'll post later.
Name:	the shed day.jpg
ID:	858949 Click image for larger version
Name:	the shed night.jpg
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #26
                        This is looking really nice Bobby. The one thing that sticks out to me is the texture map on your wood fence. It looks like a quarter sawn wood pattern with lots of figure (looks great for furniture, but not realistic for fence material). It should probably be a flat sawn wood pattern, which is what is typically used for fence material. Of course, if you're using some kind of spec'd material, ignore my post entirely. Except for the "looking really nice" part....
                        Work:
                        Dell Precision T7910, Dual Xeon E5-2640 v4 @ 2.40GHz | 32GB RAM | NVIDIA Quadro P2000 5gb | NVIDIA GeForce GTX 980Ti 6GB | NVIDIA GeForce GTX 1080Ti 11GB
                        V-Ray Benchmark: CPU 00:52 | GPU 00:32
                        Home:
                        AMD Threadripper 1950X 3.4GHz 16-Core | 32GB RAM | (2) NVIDIA GeForce GTX 1080Ti 11GB
                        V-Ray Benchmark: CPU 00:47 | GPU 00:34
                        https://pcpartpicker.com/list/kXKcxG
                        • #27
                          those dark roofing supports poke out further in the night view than in the day.
                          • #28
                            Here, is the courtyard. I Have some work to do!
Name:	the shed courtyard.jpg
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #29
                              Yes, something went wrong there. Somehow, they got longer.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #30
                                [ATTACH=CONFIG]27045[/ATTACH]
                                Looks very nice so far. The people looks nice too, are they renderpeople?
                                ...and I'm loving the effect you're getting with your ArionFX presets!
                                Kind Regards,
                                Morne
