Barrett Lane Project
  • Barrett Lane Project
    Some early gray scales, but with simple materials and light setups, render times are insanely fast. I hit render, with progressive and GF+LC, and it was almost instantly clean enough at 4k.
ID:	883335 Click image for larger version
Name:	front - left.jpg
ID:	883336 Click image for larger version
Name:	back - right.jpg
ID:	883337 Click image for larger version
Name:	back - left.jpg
    I am going to keep this one simple and only use materials made from scratch. For exteriors, reflections are almost unnoticeable, except for glass and metals. I'll start with basic diffused, unless it needs more, and I bet I'll have fast render times with 3.30.03. Also, I renewed my Forest Pro, so hopefully that'll be faster, too.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Nice and clean geometry, doing everything from scratch sounds like a great idea, that way anything that takes too long to render you can see what it is and what is making it take that long to render and learn that way.
      Progress...
Name:	front - left 2.jpg
      It is heart breaking when the client says, "can we raise the camera about 20'. so we can see as much of the back roof as possible?"
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Ha! Nicely done though, I like the landscaping around. Used Forest Pro thing?
          Thanks! Yes, I used Forest Pro on this one. I'll be changing things; the front yard will be more manicured. I feel good about this one. It's early, but I already like what I am seeing.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Here is an update.
            Hopefully, the next one will not be 20' higher like the client requested.
Name:	Barrett house.jpg
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Here is an update.
              [ATTACH=CONFIG]28083[/ATTACH]
              So if you don't mind.... I LOVE the overall detail, but there is something about the camera angle, and the tree on the left (maybe right too) that makes this massive house look like a little doll-house. It feels like the scale is completely off.
                They're looking great - your default leaves look really natural!
                  It might be the angle, but it is what it is, I guess. The driveway is pretty steep and I do have a small DOF going on, so maybe a combination of things are going on.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Thank you! I tried to keep it soft, but I am used to sharp, so I have to get used to it. Looking back at my work a lot of comments are they are too sharp. The single story part is existing and hasn't changed; the two story is new. To highlight the new, I put the old in slight shadow.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Hey Bobby,
                      Looking great, would you do a "Beauty Shot"? I mean, an extra shot even if it is not for the customer, something you can do to show off?
                      I have seen a lot of the renderings you have done and quite like them a lot. It would be good for practice too.
                        Thanks! I have been running projects back-to-back for over a year, so the time is limited. When I upgrade my hardware I could cut my render times in half and be able to do more leisure work.
                        Originally posted by padre.ayuso View Post
                        Hey Bobby,
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Update. I am using a new monitor and it was really washed out, so I added some contrast, along with other changes prior to the new monitor. I'll have to look at it on more devices.
ID:	859557 Click image for larger version
                          The back of the house is a free-bee, so I didn't spend much time on it.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Like it, has quite a natural feel to it
                              Thanks. it went pretty smoothly, but if the client has any changes, there are a few things I think I'll change.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
