This is a house in town with ski runs shown in the distance. I'm working on the opposite (South) view which will be a summer scene and I will add that to this thread as soon as it's "done". As always I welcome any comments /critique.
Depot 440
Depot 440
mark f.
openrangeimaging.com
Max 2025.2 | Vray 6 update 2.1 | Win 10
Core i7 6950 | GeForce RTX 2060 | 64 G RAMTags: None
Thank you for your reply. Yes using displacement and it opened up the corners. I painted out most of that but will improve per your helpful observation.mark f.
mark f.
Originally posted by OPEN_RANGE View Post...Yes using displacement and it opened up the corners. I painted out most of that but will improve per your helpful observation.
-Alan
Hi Alan,
No I have not tried that but I will and thanks for that tip.
I often invert the displacement map (if needed) and use a negative displacement and to avoid this corner opening up issue. with the stone base texture that just wasn't working it wasn't producing the desired effect. The negative displace seems to work best for things like mortar joints, siding/shingle courses... which makes sense.
Thanks again I'm definitely going to try that.mark f.
