WOOOW
reed chairs
EVEN IF ARE PRESENT SOME LITTLE IMPERFECTIONS ON GI SOLUTION, I WOULD SAY : NICE RENDER NOTHING MORE!!
: :P
OBVIOUSLY IT'S A JOKE
VERY VERY VERY GOOD MATERIALS ON CHAIRS AND NICE ENVIRONMENT LIGHTING IS VERY VERY NICE TOO
Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
https://www.facebook.com/essetreddi..../photos_albums
Stephan,
This is rendered in 1.45.78. Are you using 1.09.03? Because displacement modifier has changed a lot since then. Anyhow, you should put the map in the displacement slot of your vray material and add a displacement modifier to your object. Use 3D displacement and check use object material. I think you need to switch off max's default displacement in the common render settings dialog when rendering ion 1.09.03. Hope this helps you.You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
Really Amazing. Great lighting and as others have said, the artifacts aren't even noticeable with all the other great points of your images.
Only critiques are that the mapping of the displacement isn't equal all around so it make the weave a little unnatural unless this is how they have to create curves with rattan furniture. Also, why are you wasting electricity with that reading light on
--Jon
Thanks very much for the map. Hope I can use it sometime.
Great rendering too!
looks great !!
what is your Vray version ?
I have 1.09.03r >>
I don't know why it didn't work fine with me !
I made the same settings,but no good result
what about the dis map tiling ? and the amount of displacing ?
do u have any idea about why it isn't working fine with me ?
The streched version look nice too Lupaz.
Gogator: that's why I didn't post a jpeg versionYou can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
Topwerk Gijs!You da man!
Groet!
MetinSevensheaven.nl — design | illustration | visualization | cartoons | animation
