test render
  • test render
    hi guys i'm new here
    c&c crits pls
    Hi Dench !
    Welcome to the forum !
    Your picture is very good, congratulations.
    The window is strangely put on the wall...
    Bye
    Gael
      thanks..i'll try to work onthat..tnx again my friend
        Yeah welcome DAC .... like the slight Bump you have on the tile's ....
        Natty
        http://www.rendertime.co.uk
          i like the materials , a lot !!!!
            gael - i'm sorry but that's not a window..it's some sort of a lighting fixture
            thank you guys..i hope i get to see your works too
              great...!
              for the lighting fixture...to make believable ( i also thought it was a small window..), maybe put some yellowish blurred tint in the corner...like a inside glow...maybe that's an idea...
                hi guys..tried working on this one..how do I create water flowing out from the faucet..is there any tutorials around for that?
                "If a greater wave shall fall and fall upon us all, then I hope there's someone out there who can bring me back to you" - The Calling
                  nice tile
                  Really love the subtle bump mapping on the ceramic tile.
                  It would be interesting to use a displace map on the bar of soap too!
                  Can you show us your material setup for the ceramic tile?
                  Byebye
                  Naomi
                    olivierfR - I tried tweaking this one for you...im not sure if it's correct
                    blueplanet - just use this as your bump map...maybe you could also explain to me the meniscus principle again..and i was just wondering how water reacts when it collides with another body of water..maybe you can help me out on this one?..tnx guys
                      hey...ok..but in my opinion,....should be slightly more contrasted in the blurred corner of the light...
                        Hi Dench, nice work! Those must be some robust plants above the closet Maybe try decreasing the displacement on the towel a bit.
                        About the light fixture : OlivierfR, in the example you've posted, notice that the frame is under the white surface, which justifies the grey falloff. In this scene, the frame is set above the white part so I guess there is no need for the internal shadow.
                          Nice! my only crit for your pics are that i think the edges are a little bit to sharp imo otherwise good job
                          It looks like you have used sharp effect in photoshop?
                          ...:::Visit my web site:::...
                            nenad - thanks! but both are actually correct depending on the type of lightbulb you use.if you try an incandescent bulb for that lighting fixture then the light would be quite evident at the middle part..while to an energy saving one the diffuser would be properly diffused.
                            spirit - thanks!let's just say that im the opposite of those who try to blur their images.try to lessen it next time
