Best Western
  • Best Western
    First stab at this one. It went well, so far. The Revit file I received was done well, so it was easy to get it into MAX and with a script I was able to create a layer for each material used. I tried to keep the light on the building, so hopefully the foreground shadows are not too gloomy.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I brightened everything up a bit.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Images are very small, I can't really see any of the detail, it's probably the new forum that is downscaling everything.
        yes it does and quite drastically....its almost useless posting somethign wiht greater detail all gets lots....i thin i will have to look around for external placement
        Martin
        http://www.pixelbox.cz
          Surely the resizing is a glitch and not meant to be like that? It's absolutely useless at the moment.
          Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
          www.robertslimbrick.com
          Cache nothing. Brute force everything.
            Another try
Name:	Best Western.jpg
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Same as the firsts for me.
              This is.... problematic !
              (Sorry for my bad english)
                Just click Full Size before posting, it's not brain surgery.
                A.
                www.digitaltwins.be
                  Yep, I did!
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    What script was that?
                      Layer from material and it is brlilliant.
                      -- put objects onto layers one layer for each material and name the layer by the material name
                      -- by Olaf Finkbeiner for www.mainworks.de
                      layers = #()
                      obj = #()
                      for o in geometry where o.material != undefined do (append obj o)
                      format "----------------------------------\n"
                      format "objects with materials: %\n" obj.count
                      m = scenematerials
                      c = m.count
                      format "materials in the scene: %\n" c
                      for i = 1 to c do
                      layername = m[i].name
                      format "material number:% | material name:%\n" i layername
                      layer = layermanager.newLayerFromName layername
                      if layer != undefined then format "new layer created: %\n" layer.name
                      else format "!! the layer was not created !!\n"
                      for o in obj where o.material.name == m[i].name do (layer.addnode o)
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        I was gonna ask about the script too.... Thanks for sharing that Bobby!
                          I've never encountered a revit model that had clear materials, most of them were multisub materials, how does it handle those?
                          A.
                          www.digitaltwins.be
                            Is the Universal Material Converter still the ONLY way to convert Autodesk Generic materials to vray?
                            • #15
                              I'll record something when I get a chance. It doesn't splice up the geometry, it'll create a multi-material and put it on its own layer.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
