Denoiser render element
  • Denoiser render element
    Maya 2017 U4 & Vray for Maya 3.6 stable nightly 27496
    NVIDIA GP100 (enabled) + Quadro M6000 (not enabled)
    So I'm getting this message when I render with CUDA along with the new Denoiser render element:
    // Warning: V-Ray : The Denoiser render element doesn't support the current adaptive sampling method and will be ignored. //
    Image Format: exr (multichannel)
    Production engine: CUDA
    GPU Resize Testures: Full size textures
    GPU Tex Format: 8-bit
    AA Filter type: Lanczos
    Max Sbdivs: 100
    Noise threshold: 0.005
    Max. render time (min): 0.0
    Ray bundle size: 128
    GI: On
    Primary: Brute force
    Secondary: Light Cache
    Can someone please explain to me why I'm getting this message and what settings I need to use in order to try out the Denoiser render elements.
    Thank you!
    The VRayDenoiser requires the new adaptive sampler method, that was introduced a few versions back, to work properly. I guess the scene is set to use the old one, but you can manually switch to the new sampler with this MEL command:
    Code:
    setAttr vraySettings.dmcAdaptiveMethod 1;
    Miroslav Ivanov
    Chaos Cosmos
      I'm confused, does this mean that the new VRayDenoiser render element does NOT work when the production render engine is set to GPU CUDA?
      There is no option to that I see to choose the sampler method when rendering using CUDA. Please explain a little more.
      Thank you for your help!
        Use the MEL command above to change the sampling method. Or alternatively just recreate the V-Ray settings from scratch.
          I do think it is a very good idea to start a brand-new file and merge everything in when working on older files that were created using pre-Vray-3.5. I was having all sorts of legacy issues but since I started doing this these sorts of problems are negated...
          -Alan
            Good idea Alan!
              Cool. I hope it helps you as it has helped me...
              -Alan
                sorry, what is the script for 3dsmax, we have the same thing here with vray3.60.04
                  Here it is:
                  Code:
                  renderers.current.twoLevel_adaptiveMethod=1
                  Margarita
                  Margarita Stoeva | chaos.com
                  Chaos QA (V-Ray for 3ds Max)
                    thanks margarita!
