Looking better ... the dark line is probably due to Boolean ! .. if you must use Boolean then make sure the object has enough subdivs to cope with it.
WIP: Bathroom with noise...
Thx guys,
Well It's an imported solid (acad 2k5) in which I did a boolean operation of 2 extruded polylines. Would it be better to boolean the regions first and extrude then ?
Natty you mean the material subdivs ? Or object -> surface properties -> subdivision presets HIGH ? Don't know if this is correct ?
Nicolaas
I mean surface subdivs ...
Have a look @ this file .. its 2 ellipses in a rectangle ... select the rectangle then add the ellipses to it through Edit spline ...then extrude.. so much cleaner and not thousands of lines all over the place.
http://render-time.com/vray/surface.max
Natty
Depends what you are going to do of coures ... but in this case a simple chamfer for the edges would be fine.
