Service Apartment 3d Walkthrough
  • Service Apartment 3d Walkthrough
    Hi,I have spent around 24 days on creating models, texturing, lighting and doing some post works and added some texts in after effects.
    All render are done with one core i7 machine using Brute Force and Light Cache (this is also my first try with BF + LC).
    Hoping you will like the video and thank you for watching.
    Video Link: https://youtu.be/SlDV-YRw2Lo
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 1 [7.00.05 build 32953]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    the text overlays give away that it wasnt done for a client, the language is super wrong. 'monotone design, one color palette, simplistic' etc is not sales language. it will scare away marketing people that you are trying to pitch to. it's a very small thing, but showing that you get it and can speak the same language as a sales team is super important when working with those people.
    The 3d is solid, serviceable - just wanted to give you that comment as you may not realise how much it will matter if you're using this to pitch.
      Nice work, well done!
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        Hi, thank you for your input, and no worry i take all kind of critiques and comments. About the text,it's was my fault, i will keep that in mind..(It's time for me to take a english course)
        Jackie Teh
          Thank you very much for your comment.
          Jackie Teh
            You dont need an English course - you need to start reading marketing materials for properties and studying the kinds of things that are said in sales brochures.
              This looks really nice and knowing that it was rendered on one machine in this short time is amazing !
              my 2 cents that try to avoid too wide lens in animation as its distortion is more visible .
              Simply, I love to put pixels together! Sounds easy right : ))
              Sketchbook-1 /Sketchbook-2 / Behance / Facebook
                Great nad thanks for your guide, will start do that from now on.
                Jackie Teh
                  Do you mean 35?24mm lens? what lens should i use to avoid distortion?
                  Jackie Teh
                    higher technically is better and reduce distortion but artisticly you can lower it to get the desired results .. Something like 30- 35 is good from my limited experience.. I think someone here can add more to this subject as I don't do much animations =D
                      Hi M.Max, thank you, sometime i am also very confuse about the difference between film gate(mm) and focal length (mm) in the vrayphysicalcamera setting, hoping someone could point me out, thank you.
                      Jackie Teh
