House near Munich and MS vs Forest pack
  • House near Munich and MS vs Forest pack
    Hi guys,
    I often get these small empty areas on my grass surfaces. I tried using collision in MultiScatter but still they appear. When I use a lot of objects they are not as frequent of course but then my grass gets too thick - many overlapping objects. Like with this fine grass area on the house plot. Any ideas? Bobby?
    www.hrvojedesign.com
    Shoot! That sucks! Bobby!!!! Did you check his tutorial on how to make the perfect grass? Check his webpage, I found it very informative.
    http://bobby-parker.com/architectura...-perfect-grass
    Good luck! Other than the grass, the main building looks pretty nice... except the ivy, it's kind of distracting.
      Yeah, I got that tip on this forum. I use Forest Pro, but just so I can get a nice grass edge, but I paste a photo in using PS. As far as your gaps, that happens on some of their presets, so try another.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        I have had the same experience with FP and wanting to fill in little voids but have to increase the density too much to achieve that. Sometimes making another similar material with some strong bump or displacement and assigning/ mapping that to the surface you are using for the FP scatter can work OK
        mark f.
        openrangeimaging.com
        Max 2025.2 | Vray 6 update 2.1 | Win 10
        Core i7 6950 | GeForce RTX 2060 | 64 G RAM
          Thanks guys...so the answer is you can't
          Actually I increased the size of the objects a bit and it's ok now.
          The client also didn't like the ivy so I removed it
            Recently we tried to tackle this common issue by using FP scatter within FP Scatter - or scatter small grass elements onto circular area but use edge density and scale so that the core of the circle is denser. Then used this scatter inside another FP scatter in conjunction with several single grass blades.
