Hi, I want to buy a new pc for vray next and my daily work, may i know which one should go for? hoping can get some advice here, thank you.
New pc for vray next
1 PhotoBest regards,
Jackie Teh
3ds Max 2023, V-Ray 7 Hotfix 1 [7.00.05 build 32953]
AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
Website: https://www.sporadicstudio.com
Email: info@sporadicstudio.com
YouTube: https://www.youtube.com/c/SporadicStudioTags: None
Originally posted by Neilg View PostI'd go with the first one. SSD is essential. to make a xeon worth it I feel you have to go dual, they demand a higher investment.
Get 64gb of ram.
since i read a lot of problem of window 10, i am thinking to use window 7 proBest regards,
Jackie Teh
Originally posted by jackieteh View PostThank you for your fast respond, do you mean if I afford to buy two processor I better buy the second one?
xeons never beat them for price to performance ratio, however if you have an unlimited budget spending $1800 on a pair of xeons will outperform an i7 - only because they dont make an $1800 i7. The ceiling is higher if you have the money - I dont think it is ever worth it to spend that much money on a processor though.
I use windows 7 at home and in work, I had a windows 10 laptop but I dont trust it to do 3d work.
Hi my pc shop here recommended me to buy AMD Ryzenâ„¢ Threadripper 1950X, should go for this one? is it support Vray Next?
and i also thinking to use window 7 on this new pc but the shop guy said it didn't not support window 7, must use window 10Best regards,
Jackie Teh
- Likes 1
Originally posted by savage309 View PostThreadRipper is supported and works great
Best,
Blago.Best regards,
Jackie Teh
Originally posted by Raven View PostIf you can afford to wait, maybe look at the Threadripper 2. They have said third quarter for release. Or get a normal Treadripper then as they will probably have a bunch of speaBest regards,
Jackie Teh
Thanks for your answer, but someone told it will got problem if using AMD mix with Intel processor, is this true? i never use AMD before, i have a lot of question in my head, like: if i do animation with my AMD pc, save file and upload to renderfarm (most of the renderfarm using intel, right?), will it got problem to render?Last edited by Alex_M; 30-06-2018, 10:57 AM.Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 3090 24GB + GPU Driver 566.14
Originally posted by Alex_M View Post
I'm using a Threadripper 1950X in combination with two Intel i7 systems for rendering. Not a single problem so far. You'll be just fine. Also, as Raven suggested, you might want to check out Thredripper 2. It is going to be 5-10% faster than the 1st gen Threadripper for the same amount of cores. Also, AMD will be offering a 24-core and 32-core variant if you need this many cores. Oh, and yes, you'll need to install Windows 10. Windows 7 won't work with Threadripper.
It really give a headache, make me feel so difficult to choose a new pc between AMD or Intel, Window 10 or Window 7...blah blah blah...Best regards,
Jackie Teh
Thank you for your clarify, the guy said they got problem with combination AMD and Intel i7, some object missing when rendering.
Originally posted by jackieteh View PostAbit sad when i know Threadripple must install window 10, i heard a lot of problem of window 10 + 3dsmax, something like when window 10 update, 3dsmax or vray will hang, and the window 10 update cannot be turn off....
Originally posted by jackieteh View PostIt really give a headache, make me feel so difficult to choose a new pc between AMD or Intel, Window 10 or Window 7...blah blah blah...Aleksandar Mitov
96GB DDR5
Originally posted by Alex_M View PostThis doesn't make any sense. No matter what brand or model CPU you use, they execute the same code. The problem with the missing objects must be because some of the machines cannot access the assets (maps, xrefs, proxies) over the network.
I've never had Windows or Vray hang on the AMD or the Intel machines with Windows 10. By the way, more and more new hardware is developed with modern OS in mind like Windows 8 and 10.
I would not say it's that difficult. Just check prices and benchmarks and see whats the best bang for your buck in your budget range. Currently, AMD are the king of performance per dollar and their CPUs are fantastic for rendering. Intel have very good CPUs but often they are 50-100% more expensive than the AMD equivalents for literally just 5-10% speed difference. The only thing that I can recommend Intel CPUs at the moment is gaming and apps that don't support multi-core CPUs.
below is the spec i get from a pc store:
AMD Ryzen Threadripper 1950X@4.0GHz (16cores, 32 Thread)
Asus AMD TR4 X399-A PRIME X399-AMotherboard
Kingston 16GB HyperX FURY DDR4-3400MHz ram Black 64GB (16GBx4)
Samsung 970 Pro M.2 512GB SSD
2TB 7200RPM 3.5" Sata HDD
Leadtek NVIDIA Quadro P2000 1st GFX 5GB
Cooler Master Platinum 1200W (90Plus) Power Supply
Themaltake Water 3.0 Extreme S/AIO Liquid Cooling S (CLW0224-B)
AOC 13294VWH FHD LED Monitor 32"
Total amount: 16900 MYR
If i want to reduce the price, what item should i take out or decrease?Best regards,
Jackie Teh
Originally posted by ijzerman86 View PostDont get 3400mhz ram, its super expensive
I think the investment of money doesn't live up to the speed increase
Running at 2800 mhz here on 3 threadrippers.Best regards,
Jackie Teh
