building another 3970x system. should i go for the same spec or change a bit?
    You can try to find UDIMM RAM, with ECC. I don't think these are out of stock...
    CG Artist
      zivmil out of curiosity, what kind of price/budget are you building this for? I'm thinking of doing something similar. Are you coming in under $5K USD? Does that include GPUs?
      David Anderson
      www.DavidAnderson.tv
      Software:
      Windows 10 Pro
      3ds Max 2024.2.1 Update
      V-Ray GPU 6 Update 2.1
      Hardware:
      Puget Systems
      TRX40 EATX
      AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
      2X NVIDIA GeForce RTX 3090
      128GB RAM
        Yea i think it around little less than 5000$. the cpu is the expensive part here. the gpu 1080Ti i take from my old computer. its still does the job really good! suppose to get the parts next week
          Hi guys Quick update, I've been running this system for a month and am very pleased with the performance.hope this info help someone that have the same dilams that i had.First I was very worried about going air cooling and not the AIO water but the performance of the noctua tr4 are great. so don't listen to all the people who say it can't cool 3970x. I read a lot users of newegg and Amazon reviews that said it couldn't!
          The second conclusion is that i love the asus case :P
          happy that i bought it over the bequiet 900
            have you done any comparisons with the 1080ti and the cpu at all?
            e: info@adriandenne.com
            w: www.adriandenne.com
            • #21
              Do you hear the Noctua second fan noiser on full load speed? Is it front 1500rpm and rear 1200rpm?
              1000 Skopje, Macedonia
              contact@narsov.com
              Mob. +389 71 382699
              www.narsov.com
              • #22
                You have to remove the stock standard rubber feet from the 2nd fan and put on the thick rubber feet that come inside the box of your Noctua air cooler. Otherwise you'll hear a distinct whine from the 2nd fan at high RPMs. Check your Noctua cooler installation manual, there's an illustration about this.
                Aleksandar Mitov
                www.renarvisuals.com
                office@renarvisuals.com
                AMD Ryzen 9 9950X 16-core
                96GB DDR5
                GeForce RTX 3090 24GB + GPU Driver 566.14
