Cpu
  • Cpu
    Which is better for VRAY?
    32-Core Threadripper 3970X or 32-Core 2x Xeon 6226R?
    The Intel Xeon Gold Series seems to be more expensive, but that doesn't make it better.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    The 3970X.
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      Bobby get 3990x you won't regret it, just be sure you get proper cooling for it.
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
        Good to know, thanks!
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I am thinking about 3990x too. But what is proper cooling according to you? I have a friend that have standard air fan for TR4 on 3990X. Another with water cooling, not sure if its NZXT or what, but all is pretty similar. And finaly another with custom loop. Every gear works, of course temperature is best on custom loop. But what do you think what is good cooling for it? Thank you.
          AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
          2D | 3D | web | video
          jiri.matys@gmail.com
          https://gumroad.com/jirimatys
          https://www.artstation.com/jiri_matys
          https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
          https://www.instagram.com/jiri.matys_cgi/
          https://www.behance.net/Jiri_Matys
          https://cz.linkedin.com/in/jiří-matys-195a41a0
            I just read Intel's new 10th gen i9 (correction) is supposed to beat Ryzen. Is this true?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              I just read Intel's new 10th gen i7 is supposed to beat Ryzen. Is this true?
              Beat Ryzen in what? And which Ryzen CPU exactly (there are like 20 different models)? 10th gen i7 is the 10700k which is an 8-core CPU. It isn't even remotely as fast as a Threadripper in rendering. It is at best as fast as the $300 8-core Ryzen 3700x in rendering.
              Aleksandar Mitov
              www.renarvisuals.com
              office@renarvisuals.com
              AMD Ryzen 9 9950X 16-core
              96GB DDR5
                [QUOTE=glorybound;n1090651]I just read Intel's new 10th gen i7 is supposed to beat Ryzen. Is this true?[/QUOTE
                Regardless of peak performance, being intel, it seems like it will probably lose on a performance/$ whether its Ryzen/i9 or TR/Xeon.
                  But with the new 10th Gen CPUs, Intel has once again made a firm claim the top performance spot with the Intel Core i9 10900K coming in at about 8% faster than the similarly priced AMD Ryzen 9 3900X, or 6% faster than the more expensive AMD Ryzen 9 3950X.
                  https://www.pugetsystems.com/labs/ar...en%209%203950X.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    That's mostly just for single core operations for photoshop. See this for vray...https://www.pugetsystems.com/labs/ar...-3rd-Gen-1764/
                    When you consider that the 10980xe is a ~$1000 chip (you can find some good deals though) and the 3950x is $725 and they get roughly the same scores it seems an easy choice. However both the 10980 and the 3950 aren't really new, they both are about a year old. I don't think intel has anything that can even compare to the 3990x at a price that is anywhere close.
                      I'm not sure where you're getting these numbers, but Ryzen 3900x is a tiny bit faster than 10900k in Vray while Ryzen 3950x is quite a bit faster at +34%. Can I ask why you are looking at 8-12 core CPUs? Do you need a budget rendering machine?
                      By the way, AMD are literally releasing tomorrow the new Ryzen CPUs based on the Zen 3 technology which blows away anything Intel has at the moment core for core. I suggest you watch the reviews tomorrow (14:00 GMT if I remember correctly) before making any decisions.
                      Aleksandar Mitov
                      96GB DDR5
                        • AMD Ryzen™ 9 3950X (16-Core, 64MB L3 Cache, Max Boost Clock of 4.7GHz)
                        • Windows 10 Pro, 64-bit, English​
                        • NVIDIA® GeForce RTX™ 3090 24GB GDDR6X
                        • 128GB Dual Channel HyperX™ FURY DDR4 XMP at 3200MHz
                        • 2TB M.2 PCIe NVMe SSD (Boot) + 2TB 7200RPM SATA 6Gb/s (Storage)
                        • Lunar Light chassis with High-Performance CPU Liquid Cooling and 1000W Power Supply
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          that case is just weird
                          e: info@adriandenne.com
                          w: www.adriandenne.com
                            Can you even buy a 30x series nvidia anywhere on earth rn anyway?
                            • #15
                              If I look at chaosgroup benchmark scores, your current setup beats your proposed setup by quite a large margin. Did you mean to write 3960x or 3970x or 3990x?
                              I would ask the same question Alex_M is asking above...
