I'll be brief as possible, I'm looking to upgrade my rig when Ryzen 7950x comes next month out but need input on what I should expect to see performance gains wise in certain areas, but my specs on my old rig first:
I7-4930k o/c 4.1ghz
ASUS Sabertooth X79
ASUS RTX 3090
Corsair 32GB (4x8GB) DDR3 1600
1 TB Sabrent NVME drive
Corsair 860w power supply
So assuming we can speculate here for a moment, I'm more than likely going 64GB DDR 5 6000 RAM (budget wise) to pair up wih the Ryzen . Beyond that I'm already satisifed with the 3090 and intend to use that as my primary render for now and since I do very light Tyflow and Phoenix FD simulations. My understanding is it doesn't require core count so much more so how fast the clock is? Correct me if I'm wrong of course. Secondly since the RTX performance is equal if not better than a 3990x based off the benchmarks and tests I've seen on YouTube I'd rather go that route since it's also more efficient for my budget.
My main concern though are during the IPR and final renders because I'm just so damn tired of having 1 GB projects for my ArchViz and personal projects, and then having to proxy everything and wait for the compiling geometry, loading bitmaps, optix blah blah, before I can continue my workflow. I don't know what's the bottleneck in this case though and need input here. Which areas of the computer are handling these steps by the way? Any ideas how much gains I'd expect going from DDR4 to DDR5? Oh and another thing, what is rendering the previews in the material editor? CPU or GPU? Another pet peeve of mine.
Thanks in advance for feedback on this, and it's 2AM my time at the moment so I may not be able to respond till tomorrow since I'm running on E
Regards.
I7-4930k o/c 4.1ghz
ASUS Sabertooth X79
ASUS RTX 3090
Regards.
