Hi all,
Requesting help and/or guidance.
Cant seem to render with GPU.
When I get errors they are:
______
[11:38:40.231] error : c:\ci\cgrepo\vraysdk\samples\vray_plugins\rt_priva te\rt_opencl_(2153) : cuda error 700
[vutils::voptix:
ptixpipelinewrapper::launch] 7900: optix error encountered in vray_optix7.cpp[315]. error code 7900
______
and sometimes 3dsmax will just quit. I've sent in all the reports.
Cant send the Scene in (work)
most of the time after rendering a few frames it stops and stops rendering,,, then If i tell it to continue then it crashes.
I did search and only found others asking for help also with the same or similar issues.
any fixes or help? at 1/3 the time the CPU renders of the same scene, i need this to work.
I've tried driver 572.16 and am currently on 573.06.
both have the same set of errors.
only happens with GPU rendering.
______
[vutils::voptix:
______
