It appears that the OpenCL support on these drivers doesn't work properly, essentially rendering a blank, black image when using VRayRT GPU. If I revert back to the previous drivers, all is well.
So just giving everyone a heads up on this. I am using this drivers to help with some viewport problems with my GTX480. So if you want to continue to use VRayRT GPU, wait for the WHQL versions which will hopefully have the problem fixed.
